AlexJag |
08-08-2020 06:03 PM |
Supercharger cooling Xkr pump need input on diagnosis
So I have a customer in with a 2007 XKR. I found a bunch of vacuum leaks which fixed fuel trim problems, everything seems to be running good. one thing that is very different from my car is when I squeeze the hose that goes into the supercharger there is almost No movement of water when it squeezed, comparing this to my car if i squeeze the same hose there's definitely water pressure.
Can you guys with an 07-09 xkr check this for me and see how much pressure you have with the stock pump on that hose? Would help to know if his pump is failing or has failed . Thanks
https://cimg7.ibsrv.net/gimg/www.jag...b8244f54f5.jpg
