tires
tires
2007 XK
Whoever had the XK before me put the same size rims on all 4. I hate it that's it's not staggered but can't do much about it right now. I have to get new tires and right now there are 255 35 20 on it. I've done just about everything on cars as far as fixing them goes but I honestly know nothing about tires. For the best ride what size tired should I get? I don't care about performance. My wife drives this car and I would say it probably gets driven like a mini van more than a sports car.
Thank you in advance!
2007 XK
Ride comfort is another story altogether, and will always be very subject and produce many disagreements between various people.
If you want a more supple ride (and less sporty driving), I would suggest the Sailun Atrezzo Z4+AS as a reasonably priced option. If you want a firmer/harsher ride and more aggressive driving performance then the Nitto Motivo are recommended, albeit at a much higher cost.
Hate to give you bad advice based on the tire that's on there as there's a possibility it's not correct for the rim.
So if not a Jag wheel with part number, please list the manufacturer and their part number (usually stamped on the inside of the wheel if you don't have the receipt from the previous owner.)
I don't have many details on this wheel. It appears to have been offered in 08, 09. You won't find a 20" recommendation on the placard for an 07.
The front is 20X8.5 with 49 offset
The matching rears are part C2P9302 which are 20X9.5 with a 26 offset. It might be hard to find those rears in Chrome if you want to keep the fronts.
The tire size you have are correct for the front of an 08/09 20" wheel. In your case, the rears as well. 255/35ZR/20
If you went with the correct rear width wheel, you'd want 285/30ZR/20.
It sounds like your wife is built for comfort so if you can't find the rear wheels in Chrome and you want to replace all, consider the Carelia 19" wheels
Carelia 10-Spoke 19x8.5 (Front) 245/40XR19
Carelia 10-Spoke 19x9.5 (Rear) 275/35XR19
A bigger sidewall will mean a softer ride, so stepping down to a 19" wheel will accomplish that and the 9.5" rear wheel will fill out the well a bit better.
You only asked about tire size. For type of tire, I suggest you run a query in the forum. You'll find an intense passion for the topic and a deep hatred of it by some but, you'll be able to discern what tire you want based on summer, all season, traction, speed rating etc.
tampamark (06-10-2017)
tarhealcracker (06-10-2017)
There is a difference between DW's and DWS's. For some reason people seem to confuse the two in threads. I might be the only active forum user with the DW, I think everyone else with continental tires has the DWS.
I believe the DW has been discontinued and is now the "extreme contact sport" or some sort.
I will be using the Continental Extreme Contact Sport when my DW's I have now reach the point I choose to retire them.
+1 on Tervuren's comment.
If you go Continental, you'll want the Extreme Contact 06, which is typically a DWS (Dry/Wet/Snow) tire -- the "06" is the newer version of the tire that Tervuren references. I got a flat on a cross-country trip recently (thankfully in the metro DC area) and after about 20 calls, the ONLY place that had one in my size in stock was a Jaguar dealership (for what it's worth, I'd point out that their price was competitive). It was in the Fairfax, VA area. They said that the Extreme Contact 06 was the tire they recommended for the XK's when owners are ready for a replacement set.
I love 'em, btw.
I love 'em, btw.
I love 'em, btw.
I love 'em, btw.
The current name for the version of what most forum users that use Continental tires is as of right now the ExtremeContact DWS 06.
I have not seen anyone else using the DW I have, so I have to be careful to ensure the distinction when I give my feed back, since I do not use the DWS. This is confusing when I referring to these tires in the plural forms.
"For the best ride what size tire should I get? I don't care about performance. My wife drives this car and I would say it probably gets driven like a mini van more than a sports car. "
I am sure that your normal setup should be wider than 255 in the rear, that contributes to the issue you mention of not filling out the wheel well. I guess the question is whether it has 9.5" rim width on the rear or if they went with the same size as the front, the 8.5" rim width. The total rim width will dictate how wide you can go on the tire.
Sean W (06-10-2017)
I'm not going to get into the tire discussion. Your signature doesn't say what your location is, but there is a member selling 4 mint Carellas. He posted shortly after you posted your inquiry. Unfortunately he doesn't list the size(s). I had Carellas on my previous XKs and thought they looked great. If it were me I would get touch with the seller and see if you can make a deal.
Sean W (06-11-2017)
Sean W (06-11-2017)
I think I'm going to spend some time looking for new rear rims and if I can't find any then I'll look for all 4. If I'm replacing tires it's perfect timing. I'm going to check into the Carellas.
Thank you for all of the advice. I live in Texas and we don't take the car out when the weather is bad(snow). That doesn't happen often so it mainly sees very good road conditions.
Sean W (06-12-2017)
