TPMS-Tire Pressure Monitoring Sensors
Old Jun 2, 2020 | 09:06 PM
  #81
Boga's Avatar
Good point Cee Jay.
Here in North America we need only the 315mhz version.
The trick in Canada is to get someone other than a Jaguar dealer to program it.
At 2 local tire shops, I was told to go directly to a Jaguar dealer.
I wish I could find an indy to do it.
Bob
Old Jun 2, 2020 | 09:53 PM
  #82
Cee Jay's Avatar
Originally Posted by Boga
Good point Cee Jay.
Bob
Program WHAT exactly? There is zero programming of any sort for our TPMS to operate. The car self-learns after driving up to sixty miles. You CAN have a dealer do it manually through SDD, but there is zero point in doing that if you have the ability to 'just drive'.
Why pay an hour's labor cost of $125 or more when there isn't any need whatsoever?
Old Jun 3, 2020 | 07:20 AM
  #83
Stuart S's Avatar
I've been on this Forum for almost 10 years and have never seen a thread about needing to have TPMS sensors programmed to the proper frequency before being installed. That simply doesn't happen because they're sold already set to the proper frequency, either 315 MHZ or 433 MHZ, depending on your location. Any installer who tells you otherwise is either ignorant or trying to rip you off.
Old Jun 3, 2020 | 08:38 PM
  #84
Olaslover's Avatar
Your car will relearn new sensors. If you rebuild the HEX code should remain the same. If they are put on at different locations than they came off, your car will relearn there new location. It will relearn a new HEX as well. If system fault comes up, drive the car for 10 miles or so between 18 and 60 mph and everything should return to normal.
Old Jun 3, 2020 | 08:45 PM
  #85
Sean W's Avatar
From the owners manual:A replacement sensor must be fitted to a running wheel in order to be recognised by the TPM system. Recognition only occurs when the vehicle is driven above 25 km/h (18 mph) for approximately ten minutes.
Old Jun 3, 2020 | 09:32 PM
  #86
Cee Jay's Avatar
Yep. Using SDD to do the sensors, SDD dictates that the spare be installed and driven, then the regular wheel/tire be put back on and run again. I tried this to fix all my TPMS problems but it didn't help anything.
Old Jun 3, 2020 | 09:40 PM
  #87
Stuart S's Avatar
I'm glad my space saver donut spare doesn't have a TPMS sensor. If it goes flat from lack of use, I'll just use my 12v inflator and pump it back up. Old School, no problems.
Old Jun 3, 2020 | 09:46 PM
  #88
Cee Jay's Avatar
I don't think any XKs did have TPMS in the spare. Regardless, SDD stated if equipped, do this;
Old Jun 4, 2020 | 09:00 AM
  #89
LstFord's Avatar
Thank you all, good information, we will all face at some point.
Jim,
Old Jun 14, 2020 | 08:05 AM
  #90
Olaslover's Avatar
I have had very good success using Autel sensors....work perfectly once programmed properly.
Old Jun 14, 2020 | 10:38 AM
  #91
Stuart S's Avatar
What kind of programming are you talking about? All that's needed is to install the new 315 MHZ sensors and drive around until they're automatically recognized, which usually takes less than 10 minutes.
Old Jun 14, 2020 | 01:43 PM
  #92
Sean W's Avatar
Maybe what Oleslover is referring to is the process of registering the sensors via SDD. It's available in SDD but as everyone points out, entirely unnecessary as they self learn. Registering is not programming though so who knows?
Old Jun 14, 2020 | 01:59 PM
  #93
Olaslover's Avatar
Autel MaxiTPMS using autel sensors....zip, zero, nada problems. Install them, start the car drive 8 or 10 minutes at over 20mph....done, or, just program the ECU with the Autel unit, clear any DTC's, start your car and go, no "learning" required. Autel MaxiTPMS has Jaguar software pre-installed, you just pick the model.
Old Jun 14, 2020 | 02:03 PM
  #94
Olaslover's Avatar
Talking about Autel sensors programmed with an Autel MaxiTPMS. Works beautifully. If you program the sensors, then plug up to OBDII you can transfer the info from the programmer directly to your ECU, clear any DTC's and then no "training" is required, start the car and it doesn't have to learn at all because you programmed your ECU prior to driving. Piece of cake.
Old Jun 14, 2020 | 02:06 PM
  #95
Cee Jay's Avatar
Thing is though, would you rather spend 20 minutes programming something or 20 minutes driving? I'd think a much more tasty piece of cake would be the one you eat while driving a fantastic automobile.
Old Jun 14, 2020 | 02:10 PM
  #96
kj07xk's Avatar
I do that for my newer, stupider, Lexus, which doesn’t relearn codes. But seems like a waste of time and money if you only bought the toy for your X150.
Old Jun 14, 2020 | 05:04 PM
  #97
bocatrip's Avatar
I have not read this entire thread. Is it a good idea to have all the sensors replaced when changing tires on a 10 year old car?
Old Jun 14, 2020 | 05:34 PM
  #98
Sean W's Avatar
A couple of ways to look at it Bocatrip. Average life expectancy of a TPMS sensor is 7 years so 10 year old sensors are on borrowed time. That said, I replaced my TMPS sensors separate from a tire change and the labor cost was $10 per tire. $40 more doing it as a one off and that assumes they would add the full $40 during a tire change which I doubt.
Old Jun 14, 2020 | 08:26 PM
  #99
Stuart S's Avatar
Buyer Beware! The price of TPMS sensors with the identical part number can vary widely. Why? TPMS batteries are molded in and are not replaceable. Be sure to check the date on the sensor. The older the sensor the cheaper the price, since the battery life grows shorter as the sensor gets older.
A cheap sensor is no bargain if its battery dies shortly after you bought it.
Old May 3, 2026 | 01:20 PM
  #100
PrDonCoach's Avatar
Default TPMS indicator light 2009 Jag XF
I have a 2009 Jag XF Premium Luxury model. I have replaced my TPMS module, all tire sensors and all the sensor antennas. I have had the system reset but the TPMS default light returns after I restart the car. All parts installed are OEM parts. What am I missing? Help
