Track day
Old 12-11-2017, 08:45 AM
110reef's Avatar
Default Track day
So I convinced my friend to sign up for a track day with me this coming Saturday. I will bring my XK, he will bring his WRX. This will be track day lite, which is for people who have not done a track day before. There is a class, then (2) 20 minute sessions on the track, which is a 2.75 mile course. I believe the sessions are no passing, follow the leader sessions, to show the proper lines to take etc. This qualifies you for later track heavy days, where you are able to pass. I have never done this before, so I am looking forward to it. (NOLA raceway)
winstonsalemncxk (12-11-2017)
Old 12-11-2017, 08:49 AM
mosesbotbol's Avatar
Received 1,197 Likes on 931 Posts
Sounds awesome. Let us know how you make out!
Old 12-11-2017, 10:01 AM
Simon Tan's Avatar
That sounds really cool. Are you required to do any safety modifications to get on the track? On the private track in my area, convertibles are required to have roll bars (don't know if the pop-up ones on the XK qualify).
110reef (12-18-2017)
Old 12-11-2017, 11:20 AM
110reef's Avatar
I did ask, because they said that some convertibles were not allowed. He wrote me back and said mine was OK. Not sure if it was because of the pop-up roll bars or why.
Old 12-11-2017, 12:13 PM
CleverName's Avatar
I love track days, but my Jag (XK or XKR) has never been to one. Track insurance is about $300 on top of entry fees. Makes for a spendy afternoon. Fire up the GoPro and have fun!
Old 12-13-2017, 12:52 PM
SinF's Avatar
Received 2,140 Likes on 1,461 Posts
Suggestions:
1. Don't track your car with old fluids. If you are close to change period for your engine or transmission oil - do it prior track day.
2. Proper tire pressures are very important. This includes not over-inflating your tires. Keep in mind, while driving fast tires heat up and this increases pressure. Over-inflated tires tend to be slippery, over-over-over-over inflated tires can blow up.
Old 12-13-2017, 12:53 PM
SinF's Avatar
You don't have to buy track insurance. Crashes are possible, but always avoidable if you check your ego at the door.
Old 12-13-2017, 01:00 PM
jagtoes's Avatar
Received 1,836 Likes on 1,231 Posts
He should also check to make sure his personal car insurance does not have a clause that won't cover the car if track used.
Old 12-13-2017, 04:35 PM
110reef's Avatar
I was not intending to get track insurance. This session will be a follow the leader type thing - I don't think I can get in too much trouble doing that. Oil was just changed. I believe tire pressures are OK, there is a cryptic statement about tire pressure on the form I have to fill out, something about 5 psi over pressure - I am assuming it is saying that I am not more than 5 psig over recommended pressure. I will most likely not push anything very hard because of the format and because I never did this before, and because I don't want to wreck the car or me. Plus, I am 56 and no longer the invincible person I once was. I am a little nervous though.
winstonsalemncxk (12-13-2017)
Old 12-13-2017, 11:44 PM
Jagdfan's Avatar
You should also have your brake fluid completely flushed and replaced at least once a year if you are doing track days. Old brake fluid can boil from brake heat during track sessions and leave you with NO BRAKES. Believe me, you do not want that.
Tire pressure for street tires is usually recommended to be 5 psi over normal to prevent pulling the tires off the rims. Modern low profile tires are less prone to that than older style 60 series tires were. you can always check between sessions and bleed air, but you can't as easily add air unless you bring a tank or compressor.
Good luck, have fun.
The following 2 users liked this post by Jagdfan:
110reef (12-18-2017), winstonsalemncxk (12-14-2017)
Old 12-14-2017, 12:24 AM
steve_k_xk's Avatar
Received 1,538 Likes on 889 Posts
Check front and rear pads
Old 12-14-2017, 12:50 AM
CleverName's Avatar
Dead accurate advice here.... I've taken an emergency runoff road, as my brake peddle went straight to the floor like stepping on a plum! Since that time, brake fluid has been at the top of my list.
Tire pressure for street tires is usually recommended to be 5 psi over normal to prevent pulling the tires off the rims. Good luck, have fun.
Along similar lines, street tires tend to roll over on their sidewalls in hard cornering, so the raised pressure helps control that. I pointed out before that many name brand tires have marking on the sidewall showing where the tread ends and sidewalls begin. I use white chalk, or white shoe polish to mark my lower sidewalls to see just how far I am scrubbing them. Inflate to avoid this. (see tire markings below) These can vary by manufacturer (Michelin used their flying foot at one time)
The following 3 users liked this post by CleverName:
110reef (12-18-2017), sharx8 (12-18-2017), winstonsalemncxk (12-14-2017)
Old 12-16-2017, 04:57 PM
110reef's Avatar
Convinced a friend of mine to go with me to do the Track Day at the New Orleans Motor Park. I had never done this before so I was very concerned, especially about damaging my car. But it turned out to be great fun. We did "Track Day Light" where you get a teaching session, then (2) 20 minute sessions on the track, where you follow the instructor around on the track and learn the line - no passing. There are "track day heavy" where you can pass, but I didn't do that today. There has been Indy races on this track, so it is a real track. The configuration that we used today was a 2.75 mile circuit.
I brought my Jaguar and my friend brought his WRX STI
Pulling onto the track:
Coming down the straightaway:
The racecar driver:
sharx8 (12-18-2017)
Old 12-16-2017, 04:59 PM
110reef's Avatar
When we got there, there was a Cars and Coffee going on, so we walked around and looked at all the cool cars.
sharx8 (12-18-2017)
Old 12-16-2017, 05:00 PM
110reef's Avatar
sharx8 (12-18-2017)
Old 12-16-2017, 05:01 PM
110reef's Avatar
sharx8 (12-18-2017)
Old 12-16-2017, 05:03 PM
110reef's Avatar
The following 2 users liked this post by 110reef:
sharx8 (12-18-2017), winstonsalemncxk (12-17-2017)
Old 12-16-2017, 05:04 PM
110reef's Avatar
They also had drift racing going on over on another track. Those guys are just plain nuts!
Old 12-16-2017, 06:23 PM
Robman25's Avatar
Brakes got a bit hot going into a downhill hairpin surprisingly the brake fluid was only just 1% moisture but obviously sufficient to cause boiling in the front calipers. Must admit the track was moist and the ABS was working a fair amount of the time. I was much more circumspect the second time on the track
Old 12-16-2017, 10:41 PM
110reef's Avatar
Did you scrape the guardrail?
Quick Reply: Track day
