Updating with LED rear lights?
I wonder why these wouldn't work for brake light and turn signal, anybody tried?
Canbus decoder
Would be alot easier!:-)
Canbus decoder
Those are just resistors in boxes with plugs on them, the exact same end result as adding ballast resistors to the wires.
Received 1,893 Likes
I guess IF the resistance values are correct, you could snip the connectors off, and use the boxes instead of ‘rolling your own’ per the George Kale PDF.
Cambo used a 6, 8 and a 12 Ohm resistors while George used 35 and a 50 Ohm resistor and another used around 9 Ohm resistors. You read load, cheramic and wirewound resistors which confuses me.
Can I ask what year LED rears became standard on the rear, noticed 2010 mentioned but was that 2011 MY?
Ask as am looking at buying a 2010 portfolio, which may/not have them?
The downside of LED cluster lights has always been the comparative hike in price compared to just normal filament bulbs should they fail.
The full kit isn't cheap (over £1000) but cheaper to source the lights yourself and buy the harness kit from adamesh for a few of hundred I seem to remember.
If your pretty competent you should be able to follow the wiring instructions. I rang up to clarify a couple of small things but Geoff was very helpful and was worth buying the kit than try and source the bits myself.
The other resistor method will work I'm sure but they can overheat? and takes longer to do! This kit mounts trailer tail lights behind the side panels so you don't see them and works by getting the right resistance so no error codes.
Looks great though so go for it!
#28
The following 2 users liked this post by Cambo:
Cee Jay (08-16-2018),
Ranchero50 (08-18-2018)
Attachment 216801Attachment 216800Attachment 216799
This is how I mounted the resistors, on plates so they are in the air, the heat is not a problem.
Using bulbs is a bit of a hack in my opinion...
Attachment 216802
Attachment 216802
#30
#31
I was planning to install the newer led rearlights on my '06 XK, but sold the car unexpectedly yesterday.
I'm left with the lights now, so if anyone reading this might be interested, i'm asking 700 Euro (thats about 800dollar or 630pound).
Located in the Netherlands but i can ship worldwide no problem.
Lights are in brandnew condition, only missing the wiringharness to make them work correctly.
#32
They are on the car and working! As different people here give different resistance on resistors I choose to go the bulb way. I used T10 socket with 16w bulbs, made a bracket and works! Really easy to change a bulb if one should brake but how often do they break?
As for the connector I couldn't get the pins out to relocate them so I cut the connector off and also cut the connector off inside the car where I connected it all together.
The fog/reverse lights are not connected yet, my plan was to cut the connector on the lights open and solder on the wires but allways a change of breaking one so am search ing for the OEM connectors. No scrapyard in Sweden has a car standing so was wondering if anybody on here knows of a scrapper with a 2010+ car where one can get the connectors? I don't think a scrapper bothers if I emailed them for such a tiny item so was hoping someone on here knows of one nearby and can cut them off and send them to me, I got Paypal to pay for it.:-)
#33
For connectors & terminals you don't need to just look for an XK you'll find other Jaguars with similar connectors & even Ford & Volvo - remember who owned Jag when your car was made. I had success walking a scrap yard and even asking an ebay seller to remove the connector from the window switch he was selling & sell it to me independently of the switch . Good luck.
#34
#35
Couldn't find a car of which I could get the connectors so I soldered the wires directly.
I've read you need relays for it to work cause they will flicker and turn off if you connect both fog lights directly due to bigger load with 2 lights. Today I tested connecting the fog lights directly to the car and they lid up just fine, no flickering or turning off!? I haven't tried the reverse side yet as the car is of the road and didn't want to start the car to get it into reverse.
Will I get the problem or does it differ between cars that some work and some need relays?
#36
So you may be lucky, but you won’t be sure until you check the backup lights.
User 070620
10-14-2019 05:17 AM
Ric in RVA
10-21-2017 03:28 PM
Navionsam
05-21-2012 04:37 PM
