Water pump leak.
I am having trouble with find a fix for the water pump bleed off hose.
https://cimg5.ibsrv.net/gimg/www.jag...eeb25f9a4b.jpg I keep leaking coolant from right here and every time I start it up a tone of white smoke comes out from around the alternator or under the water pump. https://cimg9.ibsrv.net/gimg/www.jag...9811d0f6ec.jpg |
From the picture, it looks like the hose has been worn by contact with metal. So if the hose is leaking, the only fix is to replace it. |
Originally Posted by kj07xk
(Post 1975202)
Should there not be a hose clamp on that hose?
Originally Posted by 110reef
(Post 1975502)
https://cimg3.ibsrv.net/gimg/www.jag...6a9cf00a46.jpg |
(Post 1975502)
This is what is in the water pump that it supposed to slide in. |
(Post 1975502)
Originally Posted by TexasTraveler
(Post 1975554)
I believe he is referring to the other side of what I assume is some kind of barbed fitting that goes inside the hose. Typically you would see a clamp of some sort on the rubber hose, but maybe not?
I am wondering if this is supposed to stay in the water pump with a seal or something. |
Did you put that clip back in?
(Post 1975567)
Not trying to be a smart-arse. But after being an engineer for 35 years, I have learned that you always ask the obvious questions first. After all this is the internet and there are all levels of competence out there.
So to better understand your problem, let me re-cap - it seems that the connection where the hose enters the metal housing is leaking. It is not leaking on the hose to plastic connection, rather it is leaking where the fitting enters the housing. Is that correct? |
(Post 1975573)
So to better understand your problem, let me re-cap - it seems that the connection where the hose enters the metal housing is leaking. It is not leaking on the hose to plastic connection, rather it is leaking where the fitting enters the housing. Is that correct? Yes sir that is exactly it. Every other forum I go to they say you need to get the new design coolant hose with the new attachment but that doesn't solve the problem because its on the housing like you said. Then others say to just take it to the dealership but I much rather not pay $150 just for them to look at it then who knows how much they will charge for the part. It's also really scarey because every time I start it up white smoke comes pouring out. |
So I see the front part of the push-in quick connector. Is there a retainer clip and o-ring still inside the water pump housing? I would think like most quick connect fittings there should be an o-ring to make the seal? Check to make sure that the retainer clip is still there to hold the pipe in place and check that the o-ring is still in place and is not worn-out or damaged...
Do you need #5 per the attached parts catalog exploded parts diagram?
https://www.parts.com/index.cfm?fuse...0-%20Liter-GAS |
| All times are GMT -5. The time now is 04:44 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
