where can i find oem parts
Ditto and since prices are all over the place I'd start there. eBay had the best prices on some stuff.
If the OP is looking for Jaguar-branded parts, then parts.com
If the OP is looking for alternatives to Jaguar-branded, for example when sourcing suspension parts, then eBay. It is helpful if the OP can recognize original equipment supplier names for those parts, as presumably those parts are of higher quality and deserve a higher price paid vs. no-name parts.
I've never been to Oklahoma but I can't imagine any reason for hiding Jaguar parts there.
A little more detail on the parts you need would help.
Holmsean research may provide OEM maker clues. Spark plugs that come in Jaguar labeled boxes have NGK printed on the plugs. Removed oxygen sensors have both Jaguar and Denso engraved on the metal sleeve of the same sensor. Standard front brake pads were TRW. I think back were TEXSTAR. (you might want to consider upgrading both to TRW ceramic.) Good chance air and cabin filters were Mahle. I think the rotors/discs were Limmerman, but they're not easy to find and now apparently made in Asia instead of Germany. Poke around the forum and actual maker may be revealed for your specific needs. (Denso oxygen sensors (not labeled Jaguar), to fit XK may be found on the innerweb for circa 25% of dealer list price $70 vs $300). (I could not find OEM for upper front control arm (wishbone) ($600 each) so used Beck Arnley ($175 each)).
JimC64
Sep 22, 2025 02:52 PM
mhessen6
Oct 12, 2016 05:37 PM
