XKR Oil cooling
Evening guys,
Looking to try to get better oil cooling for my 5.0 SC XKR, as the standard oil cooler, being in the engine V, isn't adequate enough. (Reaching 130°C oil temps around the nurburgring) Is there a way of adding a second air to air oil cooler? As i don't fancy trying to find a way of modifying the original cooler or taking out the supercharger/intake manifold just to access it! Thanks in advanced |
Once you pull the nose off you'll see how much room you have to add another cooler. There's actually a good bit of room but the plumbing will be a nightmare. You'd probably have better luck with a larger cooler versus multiple ones.
Originally Posted by Ranchero50
(Post 2064414)
How are you reading the oil temperature and do you know where the temp sensor is? Also, what was the coolant temperature when the oil was at 130 deg C?
Originally Posted by TXFireblade
(Post 2064438)
Originally Posted by pauledddy
(Post 2064440)
With the torque app via ODB, it uses the standard sensor that's in the diff I imagine?
Are you using the additional PIDs for Torque to read the oil temperature? https://www.jaguarforums.com/forum/g...p-more-213503/ |
(Post 2064373)
................. adding a second air to air oil cooler? ............
I know, semantics. |
Originally Posted by Cambo
(Post 2064445)
Um, are we talking about the engine oil or the diff oil?
Are you using the additional PIDs for Torque to read the oil temperature? https://www.jaguarforums.com/forum/g...p-more-213503/ Engine oil, I didn't mean to put diff lol |
Originally Posted by Cee Jay
(Post 2064451)
That'd be tricky, it'd probably have to be an Air-to-Oil cooler, as oil isn't air.
(Post 2064453)
Yes I was using that exact one
Engine oil, I know how to read.. So I would have the same question as TXFireblade, what was the engine coolant temp when the oil temp was up at 130degC? |
(Post 2064456)
Okay, but you wrote "it uses the standard sensor that's in the diff I imagine?" hence my question.
So I would have the same question as TXFireblade, what was the engine coolant temp when the oil temp was up at 130degC? I can't remember what the coolant temperature was, but I know when I went around track that it flashed that it was too hot, plus he didn't type that second part so I didn't see that. This has nothing to do with what I originally asked, if you can't help with my original question, don't comment. Simple. |
(Post 2064470)
Yeah I corrected myself
Easy there tiger, he's (and the rest of us) is just trying to understand the question.
I don't have a detailed description of the flow through the lubrication system but based on the manual I think the flow goes from the sump (oil pan), through the oil pump, through the oil cooler, through the filter, into the block/heads/bearings/etc. and then back to the sump That would mean that the oil returning to the sump was at the highest temperature in it's cycle through the engine. If this is correct, the oil will start it's lubrication/cooling job having just left the cooler so it should be at the temperature of the coolant or thereabouts.. |
(Post 2064417)
That's the issue, the standard oil "cooler" uses the coolant as well, so would be a massive job to upgrade!
Do you have the free X150 service manual? Tons of excellent info in there about all of the systems on these cars. |
