XKR Purchase
Old May 17, 2026 | 05:38 AM
CM1237's Avatar
Default XKR Purchase
All,
Trying to talk myself into buying this..
https://www.autotrader.co.uk/car-det...-mileage=10000
Anything I should be asking.. im told full service history etc..
Sunday fun car for me!
Old May 17, 2026 | 05:47 AM
bladerunner919's Avatar
Wrong forum. You need https://www.jaguarforums.com/forum/xk-xkr-x150-33/
Old May 17, 2026 | 08:29 AM
Cee Jay's Avatar
Originally Posted by CM1237
All,
Originally Posted by bladerunner919
??? This thread doesn't say "Moved" by an Admin, and it's in the correct forum. I dunno.
Anyway, before you buy this, get a Pre-Purchase Inspection! A couple hundred quid, and you could avoid potential very costly problems. OR, the PPI could be the bit that convinces you to buy one of the best cars ever produced for the cost.
Yes, documentation of services could help, but not necessarily the whole story.
Old May 17, 2026 | 08:49 AM
CM1237's Avatar
That's a good idea, cars based in north London.. the ideal place is actually right by me in Bristol.. Ill see if I can search out a good place to have one...
Old May 17, 2026 | 07:52 PM
davidmaria1's Avatar
I always do a Post Purchase Inspection.
I just love a great surprise!
Old May 17, 2026 | 07:54 PM
Stuart S's Avatar
You're considering buying a 2014 XKR with 54,298 miles. Read this entire thread:
https://www.jaguarforums.com/forum/x...ay-nay-290765/
Rubber parts deteriorate over time, and eventually all the suspension bushings will need to be replaced. Most people believe that parts are expensive, which is true if you buy genuine Jaguar factory parts. But aftermarket parts can be a bargain, as many OEM Jaguar suspension and other parts are interchangeable with Ford parts.
l recently had my indie ASE Certified Master Technician replace
all my front and rear suspension bushings at a cost of $1,200 plus labor. I had this done because my XKR is a keeper. I did not replace the original CATS shock absorbers, as they were still good. See: 2009 XKR Portfolio Convertible suspension replacement.
Old May 17, 2026 | 08:02 PM
Stuart S's Avatar
That belated PPI is often called grounds for divorce!
Old May 18, 2026 | 03:01 AM
RobT-UK's Avatar
Managed to post this in the wrong forum ! Doh!
I always check the UK Gov MOT website to check car history.
Just checked this vehicle and its clear but has and advisory regarding front nearside wheel which you might want to check.
I paid for an engineer to check out my potential purchases and I'm very happy with my '09 N/A convertible.
Good luck
Old May 18, 2026 | 03:45 AM
Jaguar!2's Avatar
if you know someone with a good code reader or if it comes part of the inspection then great. every car I buy I will rock up with this if the colour in the sellers face changes then before its plugged in you know something is wrong. Have the belts, tensioners and water pump been replaced for example. Check for paint blisters, head lining and signs or drooping? It looks really nice though and love mine :-)
Old May 18, 2026 | 08:15 AM
dman928's Avatar
We all drive old Jags.... Every day is a new surprise!
Old May 19, 2026 | 02:21 AM
justinhill's Avatar
Good luck
Agreed about checking the MOT history. Seeing a past MOT failure for something stupid like bald tyres, failed brake light, worn out windscreen wiper blades etc is a strong sign (to me) that the then owner wasn't much invested in the car and probably wasn't looking after it. Combing this with registration plate history (my car had had two different cherished plates on it over the years) buld up a picture of what kind of owner had the car when and for how long.
Old May 20, 2026 | 01:34 AM
CM1237's Avatar
Thank you all so much for the input!
NJJAGBOY
May 18, 2026 10:15 AM
vanremog
Aug 6, 2017 05:37 PM
Dennis07
Jul 11, 2012 07:41 PM
DaveNC
Sep 7, 2010 05:06 AM
