xkr wont start
2014 XKR wont start with charged battery, thought maybe smartkey battery and changed also, still dead.
At first I had lights then charged battery full, now nothing. |
OK what is the voltage at the battery. Is it 12.6V or better. If so do a reset by removing the positive and negative terminals from the battery and then touch them together for 10-20 seconds. Then reattach and see what you have. Also how did you charge the battery and with what type of charger.
Originally Posted by Huff
(Post 1845484)
If you pumped the brakes trying to start it, you may have pressure already in the brake lines, so try 'standing' on the brake pedal while holding down the 'start' button. I mean it, really put your foot into that brake pedal.
(Post 1845484)
At first I had lights then charged battery full, now nothing. WAG says loose battery terminals but don't have enough info to go off of. Really need some details. I'm about 40 minutes away if you really need help with it. |
Originally Posted by Ranchero50
(Post 1845566)
..... I'm about 40 minutes away if you really need help with it.
Graham |
