Go Back  Jaguar Forums - Jaguar Enthusiasts Forum > Jaguar Models ( Classics ) > XK120 XK140 XK150
Reload this Page >
body stabilization needed for frame off restauration?
XK120 XK140 XK150 1948 - 1962
Old 01-14-2019, 02:11 AM
Default body stabilization needed for frame off restauration?
Hi all
I'm about to begin the restoration of my 140FHC and I was wondering if there is any need to stabilize the body before lifting it off the chassis? I thought about removing the doors and then welding two square profiles in lieu of the doors on each side to stiffen the body.
Or is that not needed with the FHC roof? The body is healthy and has no significant corrosion, and the workshop manual does not mention anything either.
Any ideas welcome
Chris
Old 01-14-2019, 08:21 PM
Jagfixer's Avatar
I would as a precaution. Be safe not sorry.
Old 01-15-2019, 08:29 AM
Received 1,819 Likes on 1,188 Posts
You need to take alot of measurements before you mount and for what you are getting ready to do i would definitly weld in bracing . It can be easy to tweek a body just from sitting underits own weight mounted to different areas other than sitting on a frame. Gotta watch a lot of resto and they all hae bracing welded in and take measurements. Whats looks good to the eye often is not to a tape measure.
Old 01-16-2019, 02:30 AM
Thanks for the suggestions. I will follow the advice and take measurements and put in bracing.
Chris
Old 02-24-2019, 02:54 PM
Hi,
Here's what we did...
Brutal (02-27-2019)
Old 02-24-2019, 03:17 PM
We also made a dolly to support it with mounting points to match the frame. Notice the adjustable height on the uprights to make sure everything is even in all directions. Yes, the floor pan has been removed and there are no rocker panels in this pic, but with the supporting custom bracing it didn't move.
Brutal (02-27-2019)
Old 02-27-2019, 08:42 AM
wow, that's pretty impressing. and a lot of work ahead!
Thanks for sharing
Chris
RodrigoKirchner
08-27-2014 05:47 AM
cazber
08-02-2013 04:30 PM
Bill400
11-15-2012 04:02 PM
Jaguar&DaimlerXJC12
09-04-2010 03:47 PM
12-25-2006 08:20 PM
Quick Reply: body stabilization needed for frame off restauration?
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
