Jaguar Forums - Jaguar Enthusiasts Forum (https://www.jaguarforums.com/forum/)
-   XK8 / XKR ( X100 ) (https://www.jaguarforums.com/forum/xk8-xkr-x100-17/)
-   -   01 XK8 bird chirp in dash... (https://www.jaguarforums.com/forum/xk8-xkr-x100-17/01-xk8-bird-chirp-dash-186126/)
Cruisin01 Jul 22, 2017 09:30 PM
https://cimg8.ibsrv.net/gimg/www.jag...059266681a.jpg
rolling down the road, I have a bird chirp somewhere in the dash. Do I have to pull the dash out to find and tighten something? ...Obviously hoping someone has experience with this issue and this is not a belt chirp. It chirps because of vibrations and bumps, so something is loose.
avern1 Jul 22, 2017 11:22 PM
I have read about this problems from a number of people. Try a small piece of rubber between the front of the dash and the windshield. No one has given a good explanation of what is loose but as far as I have read the only recommendation is to remove the entire dash assembly and carefully reassemble it.
sklimii Jul 23, 2017 07:15 AM
I've moved your post from the General Tech section to the model specific XK8/XKR section for better response.
check the upper shock mounts for crumbling foam - mine made an insane chirp that sounded like it was coming from the dash when they disintegrated due to metal-metal contact.
mhminnich Jul 23, 2017 10:14 AM
Ditto on the shock mounts.
Cruisin01 Jul 23, 2017 09:03 PM
chirping
I have new ones purchased that I haven't installed... next on the list of to do!!!
check the upper shock mounts for crumbling foam - mine made an insane chirp that sounded like it was coming from the dash when they disintegrated due to metal-metal contact.[/QUOTE]
dr.fixit Jul 30, 2017 01:00 PM
The defroster vents at the front edge of the dash tend to warp from the heat and lightly vibrate against the windshield causing that annoying sound. I put a small piece of silicone rubber and the noise dissappeared.
MediaBobNY Jul 31, 2017 10:35 PM
Ditto again. You'd swear the noise was coming from the inside but it isn't.
batroute Aug 1, 2017 07:55 AM
Likely the shock mounts but could also be the cross brace struts - one of mine had worked loose. You'll need to remove the wiper blades and panel underneath to check.
Thomasso Aug 2, 2017 09:58 PM
Had same problem with my 01 XKR, very irritating. Drove a couple thousand miles that way. Squak in dash -windshield area. My problem was outer windshield moulding rubbing in the corners. A small piece of rubber tape in contact areas took care of problem. Also had a similar noise on 98 XK8, the old piece of matchbook cardboard trick between the upright wood grain and console woodgrain took care of that. Do they still make matchbooks?
jimborino Nov 21, 2017 02:38 PM
Off topic I know but - TWINS! :D
https://cimg7.ibsrv.net/gimg/www.jag...6b92c430c9.jpg
Cruisin01 Nov 21, 2017 03:04 PM
bird chirp
It was the top shock mounts. Changed the mounts and chirp went away!
Cruisin01 Nov 21, 2017 03:06 PM
too far away to have a race. But yep!! Twins! How many miles does yours have on her?
dsd Nov 28, 2017 08:19 AM
what part number are those?
thanks.
Cruisin01 Nov 28, 2017 10:06 AM
MJA2170BD
© 2026 MH Sub I, LLC dba Internet Brands
