Jaguar Forums - Jaguar Enthusiasts Forum (https://www.jaguarforums.com/forum/)
-   XK8 / XKR ( X100 ) (https://www.jaguarforums.com/forum/xk8-xkr-x100-17/)
-   -   1999 XK8 with rough idle AFTER SHUT DOWN (https://www.jaguarforums.com/forum/xk8-xkr-x100-17/1999-xk8-rough-idle-after-shut-down-295458/)
XK8WGM Mar 22, 2026 02:25 PM
Seems to happen most times. I had the throttle body reconditioned by ASE and it seemed to fix all of the engine stalling and messages leading to failure and limp home mode.
Now, I can get in it and crank from cold start, drive for an hour, and after stopping for lunch, get back in and it will crank right away but stumble/shake with yellow and red light on dash (no codes or messages). I seem to have to rev it a bit to smooth out the rough idle and then its fine for the drive home.
Is it still the throttle body? Or other things to look out for?
Einhead Mar 22, 2026 04:38 PM
Would it make a difference if you with ignition on, before you start it, give the pedal a couple of strokes first? Im thinking if the butterfly isnt seated properly.. But, it seems that it does not get enough supplementatry fuel or air at start.. or to much.. Cleaning of MAP sensor maybe?
E
Warmuthb Mar 23, 2026 07:16 AM
This is per Gary R. Van Remortel’s XK8 Bible.
Quote
“Anytime engine is shut down and started back up in extremely hot conditions with insufficient time to cool, vapor may have formed in dead-ended fuel rail, with winter blend fuel increasing this propensity. Little can be done to insulate Steel fuel rail from conducted engine heat except to keep cooling air flowing through engine bay. If you get a lazy fuel injector, engine may start, but idle roughly until excess fuel burns off. A scan tool may show DTCs P0301 through P0308 and, if it happens again over a short period of time, you may get a MIL/CEL and DTC P0316.
Injector cleaning and flow balancing may be needed.“
I will also add that you may want to check your fuel pressure at the fuel rail…and if your fuel filter has never been changed, or is due for changing you may want to think about that as well.
Brian W.
michaelh Mar 23, 2026 03:29 PM
Red/Amber check engine lights may indicate misfires, which codes will clear once the car is running OK. Next time it happens, try turning off the ignition before the motor smooths out, then check for any DTCs.
Note 'you may get a MIL/CEL and DTC P0316' in Gary's bible should read '...and DTC P1316' (Misfire excess emission)
XK8WGM Mar 23, 2026 05:15 PM
Also, what exactly is MIL/CEL?
XK8WGM Mar 23, 2026 05:18 PM
Where can I get access to this XK8 Bible. Should I be putting fuel injector cleaner in gas?
XK8WGM Mar 23, 2026 06:02 PM
Michael,
I had to search for Jersey Island location. I thought it was closer to GB but read not actually a part of GB. It must be very beautiful there. I have been to England and France which you are between.
The big question is living on an island 9 miles by 5 miles, WHY would you want to have a XK8. By the time you get up to speed, you have to turn around and come back. :icon_bike:
Thanks for your help.
michaelh Mar 23, 2026 06:07 PM
MIL = malfunction indicator lamp
CEL = Check Engine light
The two are interchangeable, and refer to the red/amber engine light you're seeing.
https://www.jaguarforums.com/forum/a...758d1591631376
...but it mainly covers the later 4.2L cars.
I believe BG44K or Techron are favourites in the US, or see this thread of drmike's:
https://www.jaguarforums.com/forum/x...4/#post2516141
michaelh Mar 23, 2026 06:49 PM
Originally Posted by XK8WGM (Post 2907669)
Michael,
We're much closer to France than the UK - 14 miles at the nearest point. Still pretty, except the waterfront and town area has suffered from mad architecture over the years...
The big question is living on an island 9 miles by 5 miles, WHY would you want to have a XK8. By the time you get up to speed, you have to turn around and come back. :icon_bike:.
I've been a Jag-lover since my teens, and some family members have had them. It also makes me feel good when I drive it:- particularly in France which is a much more pleasant experience than the UK.
There is no rational reason for owning an old Jaguar and, AFAIK, no known cure for the affliction. Plus, Mrs. H bought it as a present for a significant birthday 20-odd years ago. Probably to stop me drooling over the car...
Misfire (which is what I think is happening) can be either fuelling or ignition related, so look to the easy stuff for starters- fuel filter, injectors, etc. as suggested above. If you can capture some codes, that may help.
It's unlikely to be throttle body related.
XK8WGM Mar 24, 2026 08:15 AM
Thank you for your help. I too have always loved the classic Jaguars but could only afford the XK8. Although now have spent three times it's worth on preventative replacement items known to fail. And, I agree, after being on a tour bus in London, I would NEVER try to drive there.
I watched some YouTube videos on Jersey to acquaint myself. Very beautiful island.
XK8WGM Apr 11, 2026 04:01 PM
Happened again today. Cranked and ran great for first half hour or so. Stopped for lunch, came back out, cranked but very rough idle. Had to feather the gas pedal to keep running. Shortly, the idle returned and ran great all the way home. On another search, I found a Radiator Cooling Fan Relay #LJA6702AA that may be malfunctioning?? I checked the fan fuses and both are good. It said the relay is located under front left headlight and bumper. I looked but could not see the part. Any ideas, clues?
PS: I added fuel injector cleaner on last trip and probably have driven the car 120 miles since then. I don't think that was the issue although it couldn't hurt.
XK8WGM Apr 11, 2026 04:03 PM
My son, a small engine mechanic suggests it might be the throttle body sensor needing adjustment or replacement. I just had the entire throttle body refurbished and replaced. Stil looking for final answer. The car is running so good except from hot restart.
© 2026 MH Sub I, LLC dba Internet Brands
