Originally Posted by XKR-DAY
(Post 2059656)
His problem is high + fuel trims on both banks.
This is his trims.................... 2379 rpm ...engine temp 183f...closed loop.. Bank 1 STFT..+0.8 Bank 1 LTFT.. +17.2 Bank 2 STFT..--0.8 Bank 2 LTFT.. +18.0 650 rpm...engine temp 192f...closed loop... Bank 1 STFT..+0.8 Bank 1 LTFT.. +3.1 Bank 2 STFT..--0.8 Bank 2 LTFT.. +3.1 Bad MAF? Fuelling problem (blocked filter, failing pump, ...)? Maybe an exhaust issue? |
There is a really good thread by RAZORBOY on the same problem you seam to be having..
Do a search and take a look Keep us informed of your progress with this issue if possible, As this help's others with similar problem's .......... |
