2001 Jaguar XK8 car won't start due to possible timing issue
Old Oct 30, 2014 | 01:03 AM
Kearnice's Avatar
Default 2001 Jaguar XK8 car won't start due to possible timing issue
2001 Jaguar XK8
I set the timing according to JTIS
I have used the tools required and I made sure the VVT was fully retarded.
Car won't start. I removed the head cover and discovered the cams are upside down
Is this a bad VVT issue... How do I resolve?
Does anyone have pictures of what a fully retarded VVT looks like?
I have disassembled and reassembled this car so much I'm clueless on whats done right..or wrong.
Thx in advance for your help
Old Oct 30, 2014 | 03:11 AM
Kearnice's Avatar
UPDATE:
The VVT on the passenger side (US) advances and retards with a 10mm torx bit.
This may be the cause to the cams going "upside down"
The drivers side does not rotate.
Is this normal? Will I need to replace the passenger side VVT?
Old Oct 30, 2014 | 10:17 AM
The Coupe's Avatar
Could you clarify what you mean when you say the cams are "upside down?"
Old Oct 30, 2014 | 10:50 AM
Mikey's Avatar
I'll take a wild guess. The cams rotate at half the speed of the crank. Turn the crank another 360* and the cams will now be right side up.
Old Oct 30, 2014 | 12:06 PM
Kearnice's Avatar
By upside down I mean...
When the cams are set properly, the flat side is up.
When I turn the ignition they rotate one half turn and rest upside down
This makes the timing & compression wrong and the car wont start.
Old Oct 30, 2014 | 12:09 PM
Kearnice's Avatar
The passenger side cams only rotate one half turn forward and backward.
The driver side cams don't rotate at all... Is this normal?
Old Oct 30, 2014 | 02:19 PM
DaveInVA's Avatar
I hate to say this but sounds like a tensioner let a chain loose.
Dave
Old Oct 30, 2014 | 03:04 PM
Kearnice's Avatar
Dave
The chains appear to be fine. I disassembled & reassembled the VVT... it no longer rotates as it did before. I will put everything back together and try to get her started. :-)
Old Nov 1, 2014 | 05:54 PM
Kearnice's Avatar
I put everything back together and the timing was "perfect". I turned the ignition and the car didn't start. I have very low compression on the passenger side. At this point. I think I need another engine.
Old Nov 1, 2014 | 11:47 PM
Kearnice's Avatar
I took the head covers off and the timing is off...not a whole half turn but maybe one or two teeth off... How can this happen? I used the tools & fully retarded the VVT. There must be a way to check this before putting the car back together and turning over the engine...right?
Old Nov 2, 2014 | 07:29 AM
cjd777's Avatar
Kearnice, Do you think it may have jumped timing before you started with your repair. If so, then you could have low compression due to bent valves. Try the oil in cylinder trick and see if it comes up on the low side, if not , get the head off and verify what is going on. A new or used head would be much cheaper than a engine.
Wayne
Old Nov 2, 2014 | 08:09 AM
batroute's Avatar
When you were timing the engine did you rotate the crank clockwise or anti clockwise? If you timed whilst turning anti clockwise it will be out.
Old Nov 3, 2014 | 10:26 AM
Kearnice's Avatar
Wayne
Thats an excellent question Wayne. A little back story on this case...
The engine over heated and "popped" 3 valve seats. I had both of the heads rebuilt as a result. During the several dis-assemblies and re-assemblies I got compression test results as high as 150psi on the passenger side so I think there's life in the engine IF I can get the timing set correctly. Its been a major challenge for me to get it right so far.
Old Nov 3, 2014 | 10:30 AM
Kearnice's Avatar
I removed the VVT bolt and rotated the VVT anti-clockwise.
I put the VVT bolt back on and tightened it to 125 Nm
I then rotated the engine by hand to ensure the chains would eliminated slack but alas...the chains were off by one or two teeth.
How do I address this?
Old Nov 3, 2014 | 01:02 PM
batroute's Avatar
So you did rotate the engine crank clockwise when taking the slack out?
Old Nov 3, 2014 | 01:14 PM
Kearnice's Avatar
I did say that I rotated the VVT anti-clockwise
Will moving it clock-wise remove the slack?
There is no mention of this in JTIS
Old Nov 3, 2014 | 02:39 PM
batroute's Avatar
How do I address this?[/QUOTE]
That's the bit I'm querying - which way did you rotate the engine?(not the VVT)
Old Nov 3, 2014 | 03:05 PM
RJ237's Avatar
The engine should be rotated clockwise when facing it.
Old Nov 4, 2014 | 12:37 AM
Kearnice's Avatar
That's the bit I'm querying - which way did you rotate the engine?(not the VVT)[/QUOTE]
I rotated the engine clockwise. Two full rotations
This didn't appear to eliminate the slack
Old Feb 24, 2015 | 02:06 PM
Kearnice's Avatar
Update:
To set the timing properly on the 4.0l
you MUST use wedges between the timing chain tensioner and the chains
This will do the trick
BrentGardner
29
Dec 16, 2024 12:13 AM
celticpiping
Sep 18, 2015 06:17 PM
1964Daimler
Sep 2, 2015 11:41 PM
dpappyp
Aug 27, 2015 06:31 AM
Jaguar Forums Editor
Jaguar Press release
Aug 27, 2015 03:18 AM
