2001 XK8 - NEED WIRING DIAGRAM OR HELP
Need wiring diagram for 2001 Jaguar XK8 Convertible so we can figure out which color wire is the Air Inlet Temperature SensorSIGNAL wire. There are five wires coming from that sensor.
Thanks in advance. Jim |
RE: 2001 XK8 - NEED WIRING DIAGRAM OR HELP
If nobody gets you the wiring before tonight Jim, I'll send you a copy of a pdf from the JTIS cd when I get home from work. I haven't actually looked up this type of component, so I hope it is there.
Matt |
Here ya go, if I could get this thing to upload. Click this. I hope it helps.
pin 4 orange
Thank you all for the help I really appreciate it.
One last question is what is the color of the other AIT Sensor wire other than the Orange one? And what is the normal operational resistance range or voltage range of the Air Inlet Temperature Sensor? Thanks a million. Jim |
