Jaguar Forums - Jaguar Enthusiasts Forum (https://www.jaguarforums.com/forum/)
-   XK8 / XKR ( X100 ) (https://www.jaguarforums.com/forum/xk8-xkr-x100-17/)
-   -   2002 XK8 Tensioners (https://www.jaguarforums.com/forum/xk8-xkr-x100-17/2002-xk8-tensioners-47020/)
aregg Dec 12, 2010 08:51 PM
2002 XK8 Tensioners
I just replaced the secondary tensioners on my 99 XJ8 so the process is not something I am unfamiliar with.
Having done that I will not remove and reinstall the valve covers without replacing the gasket so am reluctant to pull the one on my 2002 XKE, as they do cost a little.
Does anyone know from which VIN number Jag went with the 3rd generation tensioners on these.
avos Dec 13, 2010 01:26 AM
Best is to check your engine number, so from 0108130000 the engine has the new metal bodied tensioners and the primary morse chain. The parts catalogue doesn't state any vin.
H20boy Dec 13, 2010 01:32 AM
check out the FAQ in this subforum aregg, there should be a quote there with the VIN cutoff.
aregg Dec 13, 2010 09:17 AM
Thank you I tried the FAQ section but was unlucky and could not find the thread, will try again and see
H20boy Dec 13, 2010 11:34 AM
1 Attachment(s)
don't be misled by the FAQ at the top of this page, what you want is the FAQ under the subforums xk8-xkr...this one.
https://www.jaguarforums.com/forum/a...1&d=1292261667
aregg Dec 14, 2010 08:19 AM
LOL, yes as you guessed I was mislead by the link at the top of this page Thanks.
H20boy Dec 14, 2010 09:53 AM
I too was in that same spot...did the same thing. I Had to explore each subforum before I found the FAQ that everyone was referring to. :)
© 2026 MH Sub I, LLC dba Internet Brands
