2002 XKR Seat control
My XKR drivers side seat will not move at all. ITs not the fuse. I read some other threads which suggested I switch out the control module, then the switch, from the working seat to the one that will not move. Still nothing. So its not the module, its not the controller, its not the fuse and from what I can tell no wires seem to be damaged or unplugged. What can I try next?
You have about covered it if you have swapped the seat control module and switch. Sure they worked on the passenger seat?
About time to take out the seat and ensure that power is getting to the motors. Sounds like not. |
I reposted this under XKR, and I mentioned it on the other post that the seats move in all directions using the memory switch on the door.
I didnt mean for that to sound rude, I was just informing you that I had reposted so that I wouldnt have to answer 2 of the same question. How can I delete this post
I was reading in the manual and it says that the drivers seat can only be moved within 30 seconds after the car is started and put into gear, so that means there must be a safety cutoff switch somewhere that allows for this to take place. You ever heard of anything like that?
