2003 Jaguar XKR
Hello...new to the forum. Was wondering if the supercharged on the dash should be lit? All other dash lights work. Also...anyone have their driver side air bag light coming on only when its hot out? During the cooler months here it never illuminated. Thanks!!
welcome the forum. please use a more descriptive subject line in the future. from other cars, hot temperature airbag lights are often caused by a bad acceleration sensor. a high level scanner along with proper testing procedure will identify if this is the exact problem. there is probably a permanent air-bag code for your issue that is stored. a high level scanner is needed to access it.
The supercharged is not lit, it is just painted on the dial.
The airbag codes are one of the few things you can get without a scanner. Linked in the sticky on the main page: Air Bag 'Flashing' Codes straight from a Jaguar TSB (in pdf) This won't tell you how to fix it or let you clear the code, but should at least tell you which sensor is the problem. |
Thanks!!
Thank you for your input and your directions... And I really appreciate the answers to my questions I will try to do a better job on any other future posts.... Thanks again
What airbag codes is it flashing? For instance you turn on the ignition the airbag symbol flashes twice. There is a pause. It flashes twice again. That would be a 2.2 code. What is yours flashing?
Originally Posted by frankc
(Post 2083960)
:) That flashing is the code. As I said its flash......... pause.......... flash again. If you count the number of flashes before/after the pause and tell us we could probably tell you where the fault lies.
Ok...I understand. My bad. I'll be driving it this weekend and its over 100 now in Vegas so I'm sure it will come on. I will make sure to get the sequence. Thank you very much!
