2004 XK8 overflow tank???/grease fittings
my 1999 vdp has overflow tank in the lower left front with connecting hose to resavoir .x..does the 2004 have a tank??? also could someone tell me how many grease fittings and approximately where they might be so I can check with my guy when he says there are none????? Thank you it advance. Ed
The coolant overflow is hidden behind the passenger fender liner.
AFAIK the only grease fittings are on the u-joints. Aftermarket ball joints may have them but yours are probably still original anyway. |
Originally Posted by edwood
(Post 2059717)
As the engine heats up, excess coolant from the Coolant Reservoir (a.k.a. Expansion Tank) passes to the Atmospheric Recovery Bottle behind the RH wheelarch liner.
https://cimg7.ibsrv.net/gimg/www.jag...dcd56d0869.jpg As the engine cools, coolant is drawn back from the Atmospheric Recovery Bottle to the Coolant Reservoir. Graham |
Thank you very much.ED
