98 XK8 top problem
Hello new to Jag world. Purchased a 98 xk8 12,000 miles. Top worked fine now no power to pump.
Welcome to the forum Mike,
I've moved your question from General Tech Help to XK8/XKR forum. Members here with the same model will be able to help. Please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some info about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum. Graham |
There is a dedicated 40 amp fuse for the pump. Check that. If it's blown, and blows again when replaced, see the "pump motor repair" link below.
(12k miles!? Wow.) |
There is a trouble shooting procedure in jaguar bulletin 501-11
What position is the roof in now and what were you doing when you identified it was not working?
