ABS Codes 97 XK8
Today I used my AE software for the first time. I have both ABS and Transmission issues so I will start two threads.
ABS Codes: C1155 Wheel Speed Front Left Input-Circuit Failed C1233 Left Front Wheel-Speed Signal Missing C1095 Hydraulic Pump Motor-Circuit Failure I switched speed sensor with right front and checked connecting wire continuity, but the codes repeated on left front. I am thinking this is ABS Module problem, and I should send it out for repair. Does anyone have other suggestions? |
You need to replace the whl spd sensor link lead harness the is tie strapped to the upper a arm. Its a wire and we all know what happens when you repeatadly bend a wire:) and you also need to send off the moddule for solder repair on the pump motor power/ground on the circuit board
Thanks Brutal, the module is out for repair. I checked the resistance of all four wheels at the connector to the abs module and they are identical. If the code repeats when I get the module back in I will replace the wire.
