ABS speed sensor resistance values?
I measured the abs speed sensors resistance values and they were all 5 ohms or so. All 4 of them are that way.
I was under the impression the resistance reading should be 2K ohms or so? http://www.jagrepair.com/images/Auto...heet%20XK8.pdf Does this mean that all 4 sensors are dead? Any thoughts or recommendations? |
Originally Posted by JagYi
(Post 425195)
I was under the impression the resistance reading should be 2K ohms or so? http://www.jagrepair.com/images/Auto...heet%20XK8.pdf Does this mean that all 4 sensors are dead? Any thoughts or recommendations? Maybe double-check your measurement procedure. But if they really are all ~ 5 ohms then, yes, it appears they're all bad. |
you should make sure you are measuring those things right. i think they are working ok
Originally Posted by nine7xk8
(Post 425235)
Originally Posted by The Coupe
(Post 425250)
He's right...these tiny little parts are more expensive than they should be. Gaudin (one of our forum sponsors, with consistently good pricing) has them priced at $ 211 each. There are no moving parts to these things...very simple...it's hard to imagine a scenario where they would ALL go away on you.
Originally Posted by dennisw
(Post 425269)
Ill bet that you can buy an half decent mechanical stylish watch in the usa for $211 so how can sombody charge the same for a bit of plastic with a few inches of copper wire...IT A RIP OFF
(Post 425235)
I measures the 3 metal strips at the bottom of the sensor. end to end strip = 70ohms end to middle strip = 40 ohms oh well, seems like all dead sensors :( |
Originally Posted by WhiteXKR
(Post 425290)
Still waaaay overpriced, but there is a device called a Hall effect sensor inside that bit of plastic.
(Post 425442)
hall effect sensors cost pennys to make.the basics of the abs senors are very simple a rotating device ( cogged thingy thats what sam called it) rotating induces a small voltage in the winding in the tip of the abs sensor this is picked up by the hall effect device sent to the cars computer.i would think that they cost £10 max to make ITS A RIP OFF:icon_shrug:
Hmm, what am I doing wrong?
I measured my perfectly fine 2000 XJR's ABS module harness and got the same 5 ohms for resistance. Yes 5 ohms, NOT 5K ohms. Pins 3,4 Pins 6,7 Pins 17,18 Pins 21,22 Right? Am I not measuring this correctly somehow? |
Your meter could be off. Changed the battery lately? When I was troubleshooting a short in one of my sensor wires, mine were all reading 1.13K.
(Post 425195)
I was under the impression the resistance reading should be 2K ohms or so? http://www.jagrepair.com/images/Auto...heet%20XK8.pdf Does this mean that all 4 sensors are dead? Any thoughts or recommendations? So, check the way you are using your meter. Measure a few things with known resistances. If you have to, buy a 1k ohm resistor and measure that to confirm you are operating your meter correctly. Then, clean out the connectors at the sensor using contact cleaner and let them dry. Measure and look for 1040 to 1160 ohms directly across the two pins on the sensor with the harness disconnected according to JTIS. |
