Apollo Wheel Refurbishing - A Rags to Riches Story - RESOLVED
Rothwell, That is imperative. I've worked on and had to take the wheels off a few XK's and they required a great deal of effort to get them off. The shelf they sit on always requires anti seize. So, yes, there and the lug holes. I had to grind off the powder coat on my bolt on wires on the Triumph. Did not like that at all, but they would not go on the hubs.
I am making progress on the wheels. Got the first coat of silver powder on them.
The hub bores were masked off but the lug holes were not. I checked and the lugs still fit easily.
They look good (already way better than the set I have on the car now) but not great - yet.
Some of the worst pitting can still be seen when up close so I will be sanding the front face and bead edge (using 120, then 220) to smooth out for a second coat of silver powder before the final clear powder coat is applied. Fortunately the powder material is the type that will bond to itself and allow multiple coats.
They should be good to go back to powder coating after about an hour of hand sanding on each wheel. I'll post more progress pics as I get along.
Received 4,180 Likes
#30
Definitely darker than the silver metallic that is on the Apollo wheels I have mounted now.
Muncie6spd (04-14-2019)
#32
Info about the powder being used.
TCI Powder
TruBond Metallic Powder Coating
Color # 9911-01007 Chrome
TCI Powder
#34
It has been a while since I updated my progress on the wheels. Summer has been distracting.
I have a second coat of powder now on and things are looking really good. I could easily stop here and they would look better than my originals ever did.
The blemishes are now down to one or two significant ones, all due to me not sanding enough.
Since I have the time (and my powder coating guys are on board) I am going to sand down one more time and see how close to perfect I can get.
Notice the blemish at about 3 o'clock.
Here's a good comparison to the original which has a much lighter silver tone and more metal flake. I have yet to add the clear coat so I expect even more shine and depth. Also notice the interior is done in the same finish as the face. My originals barely have any coating on the inside, almost looks like over spray and really poor quality.
I will update again after I get another coat of powder on and (hopefully) also have the clear coat as well.
I know it seems like this is taking forever but we have only about 12 hours invested in the restoration so far. I am guessing about 7 or 8 more to get to the finish line but it all happens in between other higher priorities.
#35
I admire your tenacity and taking your time to get it right. You are fortunate that you have relatively easy access to the right facilities and processes. Your final product will look so much better than chrome does. At some point I will still have to deal with the one front Atlas chrome wheel on my wife's 2006 XK8 that has been gradually pitting in several spots for a couple of years now. The tire still holds its air and the wheel still looks decent from six feet away so I continue to just keep it clean and ignore the gradual pitting for now....
For the 147th time, just let me say that I truly despise ALL chrome wheels....
#36
rothwell, great story! My 2004 came with two problems. A leaper on the hood and chrome wheels. Even though the chrome wheels are perfect, they have to go. Now I have another project to add to the list.
Still have not figured out how to plug the holes in the hood from the leaper. Any good ideas out there??
#37
Think of it as being within the window of time where you can sell them, where the wheels are still good enough to not be repulsive, and the tires are good enough for a least a winter. Keep your eyes open for a replacement set that you like (or can live with), get a new set of tires for those, and then sell the old set on CL. Chances are the sale will mostly offset either your new-to-you wheels or your tires, and the difference will put you on the better path with new tires. I have done this on 2 separate cars, and, besides the issue of spending money upfront, the old set (with tires!) always eventually sells locally near the asking price.
#40
