A-Arm bushing source?
I need to replace the upper A-arm bushings. Where is a good place to get them?
Thanks! |
try any of our sponsors: SNG Barratt, Jagbits, Coventry West. Or try Welsh or RockAuto
We have them!
replaced mine with ones from motorcars ltd. inserted them using a c clamp . to make things easier purchase another bolt to use as a guide to hold the washers in place push the shorter bolt you bought out with the bolt that holds everything in place
Decide first whether you want to go OE rubber or aftermarket polybush. Polybush gives a harsher ride but longer life (the bush - not yours).
It's an hour or so a side if nothing is seized. If the old bushes are seized onto the fulcrum bolt it can turn into days of alternate heating and hammering to free it. Graham |
