battery not charging light....can i change the instrument cluster?
The battery not charging light and message was coming up frequently and the mechanic traced it to a slowly failing alternator which has been changed.
But the light still appears sometimes and it has been suggested that the instrument cluster (the 3 big dials behind the steering wheel) are at fault. I have found a secondhand cluster for not much money - can i just take the old one out (as shown here) https://www.jaguarforums.com/forum/s...ght=instrument and put the repalement one in? or is it much more complicated than that - do the clusters have to be programmed to the car....will the car have an electrical melt down if it doesnt have its original cluster? mine is a 1997 - i've seen another '97 cluster from an XK8 and a slightly cheaper '99 from an XKR. Is this feasable? |
Straight swap no programming needed and if you are lucky you might wipe a few 000s/miles off the trip meter ;)
Thanks for that. I'll get the cheaper one and see how I get on.
