Battery Replacement Recommendation - UK
Hi Guys - i feel my 1998 XK8 could do with a new battery before winter - any recommendations? I'm in London UK.
Thanks ;) |
Normally, I just go with the lowest cost for the highest power. However, I thought I was lucky to actually find a repacement battery for Kitty at Walmart. It's specifications exceeded the OEM's and it cost less than an alimony check (:icon_rant:) . It's been in the car for two years and 40,000 miles - no problems.
Is this any good - well priced etc? Bosch S4 Car Battery Type 019 95Ah 800cca Sealed 4 Year Warranty 595 402 080 | eBay
I got a Varta H3 100Ah recently from
www.battery4cars.co.uk Battery is : VARTA Car Batteries by a leading UK Car Battery online supplier. for £82.00 + delivery at £9.99 = total £91.99 which seemed like a very good deal. Arrived quickly - well packed - included vent elbow - can recommend. Cheers, David. |
For comparison I bought mine ( I was desperate ) from Halfords for £140.
hi mate,the bosch s4 800cca perfect I have the same on mine and never lets me down,did you make sure you got the type with the vent.
Can i use an Optimate 4 charger
to charge my 1998 XK8 ?Optimate 4 Battery Charger - Demon Tweeks
I'm going to buy a new battery soon - is these a specific name or number for the properly vented battery - looks like the previous owner bought quite a cheap one. Thanks for the help guys. |
ok the battery i have in it now is a: Lion Battery looks like it's 88Ah
My guess is this is a general one and not the best for the car. The full ref nos for it seems to be 017 88Ah EN 680cca Lion 017 Car Battery 88Ah 680CCA 3 Year Warranty any thoughts? Thanks. |
To quote a post I made on another Jaguar Forum!
The OE battery for your XK8 is a VARTA made in Germany. Part Number C2D22312. Specification is 90Ah and 800 amp. Cost from Jaguar last month was £95.79 (less any discount your dealer may give) plus VAT. Just Google [Jaguar + XK8 + Varta + battery] and it will return several UK suppliers. Graham |
Brilliant - thanks Graham that's the one for me - hope u don't mind a dumb question - will that come ready to fit - no charging up or anything?
I've been looking at the this link for reconnection: https://www.jaguarforums.com/forum/x...ect-faq-74146/ |
They always come from a Jaguar Dealer charged and ready to fit. If you source from elsewhere, check before you buy. The adaptor for the vent is usually packed separately. There's a blanking plug to remove and the right angled vent adapter is then a push fit.
Things to consider with battery disconnection are: 1. radio code required (for UK vehicles) 2. reset window limit switches 3. fuel trim adaptations will automatically reset to default values but will 'relearn' as you drive Graham |
