Been sitting about a year and...P0171 P0174
So I had my 2002 xkr laid up for about a year. Surprisingly it started right up. Prior to sitting it ran just fine. I was driving to get an inspection and the check engine light came on. All monitors were set from forever....But now... P0171 P0174 . I also noticed it felt a bit sluggish and wouldnt rev. I cleared the codes, still felt sluggish but now revved...Same codes came back. Filled up with some fresh 93. No restricted performance message.
So I refastened the air intake, checked for leaks with some map gas (figuring the idle would change). I didnt see cracks or breaks anywhere in any of the lines. Same thing.
So ill check back tomorrow to see if I can find any cracks again. I do have a mina air intake I can swap to see if it does anything. Ive also seen a fuel filter can cause this issue as well?>? I also can assume teh MAP gas may not have worked.
Anyway any advice would be appreciated
Damon
Damon
I had a similar problem. Turns out mice had gotten into air intake and stored a bunch of food below the air filter! I cleaned out the air filter box, replaced air filter and cleaned the mass air flow sensor.. I cleared the codes and everything is fine. Make sure you use mass air flow sensor or electronic contact cleaner to clean sensor.
Hope it is a simple as that!
Alan
Alan
My 02 XKR was throwing P0171/ P0174 codes a few years ago due to leakage in the Part Load Breather Circuit. I had done a Tygon hack that was sucessful until the Tygon delevoped cavitation. A little over 2 years ago, I did a stronger but still temporary hack that is working to this day. Also note that when it would throw those code, I sometimes would have Restrictive Performance mode kick in, especially when decelerating.
Here is a link to when I did my 2nd hack.
https://www.jaguarforums.com/forum/x...e-part-219539/
No VVT thanks!
Alan
Alan
The data shows that at 1400rpm and 23%load, your trims are too high (> 25%). From the looks of it, there is a "new" air leak (high short term trims) at that rpm/load. Normally, static air leaks tend to be most prominent at idle as they become a high %tage. Here, it is at a higher rpm and load, and on both banks.
First, do a visual inspection of the usual suspects (intake tube AND resonators, those supercharger seals that get dislodged, etc.).
Next diagnostic procedure would be to do a smoke test to locate all the static leaks.
Last, to throw parts at the problem, get a new air flow meter (you can try cleaning it first).
I was leaning in the same direction including the MAF clean. So possibly a mouse nest or a cracked line. Ill change the fuel filter but it does start right up and idles well. What I dont know is if there is something that would open up and then flag the leak due to a lean issue. The code doesn't come on right away. I drove a few hours before it popped on again
Z
The vent line in the valve cover seems to move around quite a bit where it goes under the sc. Not sure if it generally has that much play or is cracked. Guess a smoke test could tell me that.
Run the car at idle (for high vac pressure) and take some kind of spray, solvent or whatever that won't leave stains... Spray around the inlets for the FI's... See if you get a change in idle. I had the same codes, punished myself doing all kinds of tests. Replaced the lower seals on the FI's and the problem went away.
One test was a homemade smoke machine. Old coffee can, used motor oil, a bunch of leaves soaked in oil and a bike pump with some fancy shmancy hoses... Worked a treat. 2 FI seat seals leaking just a liiiiittle little bit. That's enough. Anyways, that's my smoke machine story...
I'm in good ol Staten Island...
The 'machine'?
It materialized out of nowhere,,,
then returned to nowhere...
That's the thing.
The 'machine'?
That's the thing.
So my air intake tube looks like brand new. I never like the way it seals at the TB so I removed everything and reinstalled. I was down to one monitor needing to be set to get inspection when the car burped, restricted performance....and both codes came up. I had done a smoke test and found no leaks as well.
I cleared codes and it happened again an hour later.
SOOOOOOOOOOOOOOOOOOOO I ripped the custom air intake and MAF off of my other xkr and installed. Now to drive around like an idiot and see whats next. I had to park the car on the street last night and ended up with an inspection ticket, I mean, how do they always know! Car runs excellent otherwise.
Also prior to this I did and let MAP gas out around SC gaskets....Nothing. Thought I had it fixed
Managed to get all monitors set besides components and catalyst...No check engine light. driving for hours..Hopefully get this set tomorrow. Because Ill be at a loss if the light comes back on.
