Best replacement XK8 roof lining
Hi All,
there are a few suppliers of replacement roof linings on tinterweb and conflicting advice as to which supplier is the better choice, is there a particularly better one than the rest ?, what results have members had with doing this increasingly necessary trim replacement, mine is just starting to sag so will need some TLC, thinking of using trim studs until get new lining rrosscoe |
I've moved your question from General Tech Help to XK8/XKR forum. This is the place to post questions about your model.
Graham |
Are you talking about a Convertable or Coupe?
When the Lining in my Coupe shagged, I took it to Joel at "Stitches" here in Houston and he replaced it with an Alcantara Liner and also under the Window area in back....Looks Great! "Not cheap" but it's not a Cheap Car!
Now if it's a Convertible, you should take it to "Stitches" here in Houston and Joel will take care of it also! Billy Clyde in Houston |
Thanks guys,
should have mentioned it is a coupe 2000 mod year rrosscoe |
1 Attachment(s)
Well spotted
Damn, you have good eyesight,
thought i would get away with it! rrosscoe:icon_attention: |
WHAT!
How did that advert get into my post?
wasn't me rrosscoe:icon_hijack::icon_hijack: |
