Jaguar Forums - Jaguar Enthusiasts Forum (https://www.jaguarforums.com/forum/)
-   XK8 / XKR ( X100 ) (https://www.jaguarforums.com/forum/xk8-xkr-x100-17/)
-   -   Best synthetic oil for 2006 XK8 (https://www.jaguarforums.com/forum/xk8-xkr-x100-17/best-synthetic-oil-2006-xk8-42103/)
jagpro69 Sep 13, 2010 08:39 AM
Has anyone had any experience with Royal Purple synthetic oil? What is the best synthetic oil?
steve11 Sep 13, 2010 12:42 PM
Some people swear by the smaller "boutique" oil suppliers like Redline or Royal Purple. I've always had more confidence in the bigger names - Mobil, Castrol, Penzoil.
Mikey Sep 13, 2010 04:26 PM
I didn't think ANY synthetic was on the list of recommended oils for Jaguars.
SilverXJ Sep 13, 2010 06:49 PM
Using oil analysis we run Amsoil in our 2002 XKR with 20,000 change intervals.
BurgXK8 Sep 13, 2010 07:51 PM
+1 on the oil analysis. With engines as expensive as they are on these cars, I think the twenty bucks extra for the test is well worth it.
You really go 20k? I was only planning to go 10k on Mobil 1 5W-30 (with a filter swap at 5k) but maybe I can stretch it.
...and if I had a nickel every time I read about what some manufacturer recommends....
steve11 Sep 14, 2010 06:44 AM
That is true for any late model owner's manual I've read (Haven't read them all, but many). Jaguar has either been silent on synthetic oils or specifically warned against them. Here is a copy paste from a 2002 MY:
Recommended engine oil
When the oil level is at the lower dipstick mark, add 1 quart (1.0 litres) of oil.
Oil specification
– API SJ / EC and ILSAC GF-2.
When topping up between oil changes, make sure that you use oil that has the correct quality level (API service) and viscosity grade.
Your vehicle’s warranty may be invalidated if damage is caused by use of improper engine oil.
Note:
Jaguar does not approve the use of synthetic engine oil in the V6 engine.
SAE Viscosity Rating
It is recommended that you use only approved engine oils to meet the SAE viscosity range/ambient temperature scale shown below.
For maximum fuel economy, 5W/30 oil is recommended.
Although it caused a lot of controversy the last time, I'll chance a restate -
I very much believe in the oil analysis and the interval in my XK8 is 12K with an extra filter only or two interim change at 4K or 6K miles. The last oil analysis I had done showed I could have extended the change to 20K miles. Most of my customers have gone to analysis with extended changes and I have had some of these cars in my care since warranty end. I only have a couple of clients still doing 3K or 5K changes, but they also don't "buy" the oil analysis for some reason. Old habits die hard.
Mikey Sep 14, 2010 08:08 AM
Oil analysis technology has it's place, but must be used properly to have value. I do not believe that a single sample will necessarily give an accurate picture of an engine's health each and every time, much like a single blood pressure reading will not confirm whether a person is/is not in good health.
I am retired from a 31 year career in the aircraft engine business, primarily in the customer support engineering end of things and frequently observed that individual oil analysis readings gave false results, either positive or negative.
In the case of a car engine, the cost of the testing would outweigh any potential savings achieved by extending the oil change interval.
SilverXJ Sep 15, 2010 06:15 AM
Yes, using Amsoil Series 3000 0w-30. Started off with a 10k interval and gradually worked up. Our 98 XJ8 likes to be changed around 12,000 though.
12mile Aug 27, 2011 07:49 PM
Woe is me no common answer
randyb Aug 27, 2011 08:42 PM
I have never believed the hype from oil products and I have real world proof to back it up.
My 95 Volvo T5R went to 356k miles and was still going strong when I sold her, engine had never been cracked.
93 vette was at 203k when I sold her, was leaking at rear seals, but could still hit 130 mph (did this twice, once right after I bought it and 2 months before I sold it), car ran great.
All total, I have had 6 cars go over 200k miles and none have ever had synthetic oils or boutique oils.
You ask how I put that many miles on my cars, I worked for just over 10 years at a job about 120 miles from my house.
xenophobe Aug 28, 2011 12:46 AM
It really doesn't matter what kind of synthetic, or dino oil you use. All that really matters is that you regularly service and maintain your car.
Which method is better? The one that you can follow the best.
© 2026 MH Sub I, LLC dba Internet Brands
