Jaguar Forums - Jaguar Enthusiasts Forum (https://www.jaguarforums.com/forum/)
-   XK8 / XKR ( X100 ) (https://www.jaguarforums.com/forum/xk8-xkr-x100-17/)
-   -   Check Engine Light/Error Codes (https://www.jaguarforums.com/forum/xk8-xkr-x100-17/check-engine-light-error-codes-1357/)
Apr 8, 2007 10:27 PM
Hello everyone, I posted a question last week about fumes in the inside of the car and noone responded. My check engine light is on now. Can anyone tell me what these codes mean. P0455, P1642, P1111? I would greatly appreciat it.
thanks
Lesa1218
2002 XK8
93xj6 Apr 8, 2007 10:32 PM
RE: Check Engine Light/Error Codes
I apologize for the lack of a response to your earlier post, but that is bad if you can smell fumes in the car.
I do not know specifically what that code means, does it say in your owners manual what those numbers mean? Otherwise take the car to the dealership or call jaguar and they will advise you on what to do. Either way you'll probably end up at the dealership, they will run a diagnostic test on your car.
Congrats on the new car, btw...make sure you find a good friendly jaguar dealership they will be needed on your xk8. I know some dealerships are very good, but we go to imperial motors and they are actually cheaper than any mechanic, so dealerships can be good
Max Apr 9, 2007 10:50 AM
P0455 - EVAP (system) leak detected – large
Possible causes - EVAPP to ECM drive circuit short circuit to ground
EVAPP failure
P1642 - CAN circuit malfunction (no explanation of "CAN")
Possible causes - CAN short circuit fault
Control module failure – check for additional flagged DTC(s) to locate
control module source.
P1111 - System checks complete since last last memory clear.
good luck...................
Apr 9, 2007 07:50 PM
[sm=bounceybounce.gif]Thank you for your responses. I took the car toa Jagdealer this morning. Everything covered under warrenty WHEW!
Lesa1218
Envy337 Apr 9, 2007 09:18 PM
There is a TSB for gas fumes in the car.
© 2026 MH Sub I, LLC dba Internet Brands
