Jaguar Forums - Jaguar Enthusiasts Forum (https://www.jaguarforums.com/forum/)
-   XK8 / XKR ( X100 ) (https://www.jaguarforums.com/forum/xk8-xkr-x100-17/)
-   -   Check Engine Warning on...then off (https://www.jaguarforums.com/forum/xk8-xkr-x100-17/check-engine-warning-then-off-10623/)
chazaroo Jan 25, 2009 01:45 PM
We were out yesterday in our 2001 XK8 and parked the car to have lunch. Upon returning to the car,
I started it up and the Check Engine Icon lit up and did not go out again like it normally does. The gauges
were all in the normal range and the engine sounded fine. We drove home (about an hour) and parked the car.
This morning I went out and started it and the Check Engine Light was still on. I took the car out for a few minutes and the light
went out and has stayed out. Again, the engine sounded and ran perfectly while the light was on. Anybody hazard
a guess as to what the issue is/was?
JagtechOhio Jan 25, 2009 01:55 PM
RE: Check Engine Warning on...then off
A fault code will be stored in your Engine Control Module memory that will indicate the cause for the warning. When you read people talking about "having their codes read", you can now share in the pleasure.
chazaroo Jan 25, 2009 04:44 PM
Where does one go to have their codes read? My spiritual Advisor says it's beyond her capabilities... she only reads palms and tea leaves.
JagtechOhio Jan 25, 2009 10:21 PM
Sorry, no crystal balls here.
Try:
Advance Auto Parts
353 E. Prima Vista Blvd.
Port Saint Lucie, FL. 34983
(772) 878-3665
In some areas, this service is no longer offered to customers at no charge. The generic scanner that they use will not read codes for all systems on your car, but you are likely to leave with an engine or transmissionfault code to research. Ignore code P1000 or P1111, those are not indicative of a fault.
chazaroo Jan 26, 2009 10:53 AM
Thanks JagtechOhio,
I'll check Advance Auto. They're two blocks from my house.
Rick Padilla Apr 27, 2011 06:24 PM
engine light
It came on suddenly. I went to the non-Jag dealer -not nunder warranty. He had a little hand-held reader, said it was an "evap" code, cranked the gas cap tighter; he then cancelled out the code, and presto! no light; I drove home a few miles and still no light. I had filled it the day bedore. Just a clue that might help someone. No telling what a repair shop might have bitten me for.
Rick Padilla May 9, 2011 10:33 AM
Well, to add to the engine light/evap code saga, the damned light came n again and stayed. And it was accompanied with the "limp home" message a couple of times, and one time it actually ran with low power. It rained mostly for a couple of weeks - maybe a factor? But two days aho - no light! Ran like, well, a striped-assed cat! I was all set to invest in a gas cap and it must have felt a disturbance in the force...:icon_bike:
© 2026 MH Sub I, LLC dba Internet Brands
