Cigarette lighter install
As stated before, my 2006 XK8 has no lighter, just the hole with no wires visible or that I can feel. Is it likely that there is the lighter wiring under the console?
If there is likely no wiring I do not want to go to the trouble of taking off the console cover. I m a novice at such things. Also if I can't install a lighter because of lack of wiring, are there any suggestions for making use of the hole? Thanks |
Well, the wiring will be there unless someone has previously done some modifications. The centre console takes about 5 minutes to get off, so you're not really going to need to invest much effort in having a look.
| All times are GMT -5. The time now is 10:22 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
