Cleaned TB and Intake
https://cimg4.ibsrv.net/gimg/www.jag...9f5a6794e.jpeg https://cimg7.ibsrv.net/gimg/www.jag...351a6c878.jpeg Intake had white residue on the TB end. It would not come off easily so I left it. TB had lots of carbon buildup around the butterfly. Cleaned off easily with MAF cleaner. Anyone know how to clean up that carbon buildup at the TB elbow below the butterfly valve? See photo. Harder to get to than it looks. |
TB cleaning
You can spray MAF sensor/throttle body cleaner on a white lint free rag and gently wipe out the TB deposits. |
Originally Posted by funracer
(Post 2039484)
...Anyone know how to clean up that carbon buildup at the TB elbow below the butterfly valve? See photo. Harder to get to than it looks. Spray cleaner into bore so it can soften the buildup. Soak the tip in cleaner and swap away. It is slow and tedious but it works. |
Or you can try this.
Link. http://www.jagrepair.com/ThrottleBodyCleaning1999xk8.htm Gus www.jagrepair.com |
