CLEAR Frt. Bumper S/M Lens & Repeaters update
Installed the new Clear S/M lens and Repeaters as done earlier by PBF. Very pleased with the look. The repeaters were no problem and S/M lens only a slight bit of work. Getting the S/M assembly removed was a bit tedious (remove H.L. access Pnl. and locate the spring clips on the housing of the S/M lamp), but the lens came off easily, however destroying the amber lens was easiest way. Used a Clear Loctite product to reattach the new lens. Installed the Chrome tipped amber bulbs (4) and was finished. Ordered 2 of repeaters, but quantity was actually 4 (2 pair). I have an extra pair of clear repeaters w/o bulbs. PM me if interested. Probably cost less than $20 incl S&H.
kstevusa, You better keep those extra Repeater Housings as the little clip that holds it on breaks quite easily......Send some photos for all to see your pretty Green Jag....It will be surprisingly better looking with the clear stuff!
Billy Clyde in Houston |
