Coil pack ohms
Hi can someone let me know which pins to read and what the acceptable range is for a working coil?
many thanks alan |
If the ohms are wrong you probably have a bad coil but if they look OK you still can have a bad one - better to use a coil tester.
I thought the coil packs were not testable with ohm meter because of the trigger circuit . I replaced all 8 recently and know l had at least one bad one yet they all showed the same resistance values on my meter.
Thank you all, that tells me what I need.
| All times are GMT -5. The time now is 05:53 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
