Jaguar Forums - Jaguar Enthusiasts Forum (https://www.jaguarforums.com/forum/)
-   XK8 / XKR ( X100 ) (https://www.jaguarforums.com/forum/xk8-xkr-x100-17/)
-   -   convertible top oil - can you name that color (https://www.jaguarforums.com/forum/xk8-xkr-x100-17/convertible-top-oil-can-you-name-color-160930/)
TexMurphy Apr 10, 2016 05:08 PM
Hi All,
Attached is a picture of a q-tip dipped into the oil for a color test as I was unsure what type of oil was in the car currently.
My level is a little below half full so looks like time to buy some oil for it. I want to be sure I guy the right stuff. It has been working great so I don't want to screw this one up.
PO had work done top and work order from October 2000 listing (2) JLM-21112 and there was a previous with same number earlier that year. No work orders since show top work.
So I need to buy the Penosin CHF 11S right?
Any of the local stores near you stock it?https://cimg8.ibsrv.net/gimg/www.jag...0380673ed2.jpg
color of oil
sklimii Apr 10, 2016 05:16 PM
Looks like the newer green stuff (Pentosin)
Yes on the Pentosin CHF 11S - I found it locally at NAPA, but O'Reilly's and Advance can order it if they don't have in stock. Also available via Amazon
TexMurphy Apr 10, 2016 05:33 PM
Was just reading the paper work passed along from PO and found SB 8/99 501-33 noted which sounds like a full system flush. Yea me and Jag for stepping up on the warranty when second owner had an issue. If I understand this correctly they would have done a full system flush, and I suspect that is why it is still working today with the newer synthetic oil.
I will check at the NAPA on my way to work in the morning they look like the best price.
Thanks Steve
© 2026 MH Sub I, LLC dba Internet Brands
