Convertible top pump upgrade odyssey begins
Old Mar 5, 2013 | 07:32 AM
Powdercoater's Avatar
Default Convertible top pump upgrade odyssey begins
Well it seems the simplest things can cause the most grief. I'm adding the pressure relief valve to the conv top pump, whether it wants one or not. Step one is remove the set screw plug but mine, after 16 years will not budge. Period. I removed the pump from the car, heated the plug to red and still no go. The driver bit broke, twice. I welded a nut to the plug. the weld broke. The whole thing is going to a machine shop today to either extract the plug or machine a new hole and fitting. Damn Sam.
Attached Thumbnails Convertible top pump upgrade odyssey begins-100_3203.jpg
Old Mar 5, 2013 | 07:39 AM
steveinfrance's Avatar
Hope you haven't cooked the internals. Red hot sounds a bit drastic!
Old Mar 5, 2013 | 07:47 AM
The body didn't get as hot as it might seem, because it's a billet. Just the plug got hot and it only took a couple of seconds to do it. I had hoped that it would soften any loctite or such. The rest of the top system is in excellent shape, like new really, and I think it's important to get the upgrade installed in hopes of preserving it. If the pump won't cooperate than I don't see other choices than to get the plug out or replace the pump.
Old Mar 5, 2013 | 08:12 AM
Gus's Avatar
Gus
A few had problems in removing the plug sorry you are one of them. Taking it to the machine shop seems to be the right thing to do.
Old Mar 5, 2013 | 10:52 AM
Success!! The friends at the machine shop, with a drill press and an easy out, removed the plug. Any thoughts about how too flush this thing in the right direction. It may not be necessary but maybe better safe than sorry.
Old Mar 5, 2013 | 11:07 AM
Gus's Avatar
Gus
The only flush is to empty the tank, fill it and run your system and empty and refill. Not necessary if the fluid is green.
Old Mar 5, 2013 | 02:18 PM
Thanks again everyone. The kit is installed and the top's as smooth as Fred and Ginger.
Damn, I let slip another geezerism.
dsnyder586
Dec 29, 2024 07:39 PM
Sprayall
May 30, 2021 08:13 AM
Sprayall
Sep 3, 2015 07:49 PM
rachelstr
Sep 3, 2015 12:59 PM
SouthernGypsy
Sep 3, 2015 10:54 AM
