Coolant leak
I've tracked down a small coolant leak to the heater hose where it connects to the non return valve - presumably the valve, being plastic, should be replaced at the same time? Am I right in thinking this is not part of the infamous octopus hose assembly?
2 Attachment(s)
Leaking at the Three Way Connector (item 6)?
Attachment 74930 (click on the image to enlarge it) If so, it's listed separately from the heater hose. Graham |
Thanks Graham - I've managed to narrow it down to the heater valve to bulkhead hose - there is a non return valve included in the hose - part number HJA6739AC for the benefit of any other member that has this problem in the future
