Damaged front undertray.
99 XK8 Convertible. Poor roads and speed bumps have resulted in the front undertray being removed. Whilst looking for a replacement is there any reason why it shouldn’t be driven? Thanks.
other than looking ugly...don't think so.
Thanks for the response Barry, my concern was about the rigidity of the underside of the bodywork. Does the undertray hold it together and if it’s been removed would there be an issue?
The undertray (apparently) gives two benefits:
1. improved airflow through the radiator and under the car 2. makes the front bumper stiffer Without the undertray in place, the front bumper is only secured around the top edge. The undertray fastened to the bottom edge makes it more of an open box with greater structural integrity. That being said, there's lots of XK8/XKR's running around with broken or missing undertrays ..... Graham |
Originally Posted by Plastic Paddy
(Post 2073113)
Best of luck, keep us posted. PS: From memory, this undertray also holds the bottom of the inner wheel well liner. If missing, the air flow may push that liner into the tire and wear it out. |
Originally Posted by GGG
(Post 2073370)
"...... being said, there's lots of XK8/XKR's running around with broken or missing undertrays ..... Graham
Originally Posted by fmertz
(Post 2073385)
".....PS: From memory, this undertray also holds the bottom of the inner wheel well liner. If missing, the air flow may push that liner into the tire and wear it out.
I've been looking for a decent used under-tray and the lower snorkel for the alternator. So far I've discovered there are no used ones in good condition. Z |
