Door insert panel replacement suggestion.
I'm getting my interior just about how I want it, inspired by my XF interior, and I want to wrap the door inserts in the dark tamo woodgrain vinyl. I've covered them several times in different suede colors and fabric works fine but there's no way the vinyl will work. The panel is a thin Masonite type board with some strange molded foam.
I need a suitable surface to cover, won't flex too much, and can have a clean edge to wrap around. |
2 Attachment(s)
Maybe you could get unfinished panels from the place that sells these?
XK8 and XKR Interiors https://www.jaguarforums.com/forum/a...ine=1384186938 |
| All times are GMT -5. The time now is 03:20 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
