Jaguar Forums - Jaguar Enthusiasts Forum (https://www.jaguarforums.com/forum/)
-   XK8 / XKR ( X100 ) (https://www.jaguarforums.com/forum/xk8-xkr-x100-17/)
-   -   door won't lock after paint job - RESOLVED (https://www.jaguarforums.com/forum/xk8-xkr-x100-17/door-wont-lock-after-paint-job-resolved-119687/)
mark campbell Jun 12, 2014 04:51 AM
painted my 1998 xk8 --in order to facilitate it i took off the exterior handles -now it wont lock --lock-unlock ---then goes into alarm when i use remote--------any suggestions --thanks in advance
jimbov8 Jun 12, 2014 05:57 AM
I would say from the sounds of it, you have misaligned something on refitting.
You may have to take it apart again to make sure everything is lined up correctly. Probable cause is the door ajar switch.
Hope this helps,
mark campbell Jun 17, 2014 05:00 AM
first thanks for your reply jim----------------found what was wrong---------had the door panel off also !!!!!!!!!well i re-plug the window switch and hung it on the door handle----------well i guess ---3-6 oz is enough to cause problems with the door lock operation ----------anyhow problem solved
jimbov8 Jun 17, 2014 05:24 AM
Glad to hear you have sorted the problem. Happy days:icon_dance-tap:
© 2026 MH Sub I, LLC dba Internet Brands
