drivers window switch
Hi guys rebuilt car from ground up and am stuck on changing drivers side window switch. Age must be catching up, any help would be appreciated.
You will need to remove the door card. Once that is done you can separate the arm rest and you will be able to access the mounting for the switch assembly.
Thanks for your help i think i went brain dead.
