DSC system fault
Really? What is that? I love to hate this car.
When did it happen? While driving, cornering, or at start up? Any other messages or lights, like ASC Not Available or the ABS light?
A few things could cause this. What are the OBDII codes?
Originally Posted by RJ237
(Post 1407476)
Originally Posted by Gus
(Post 1407690)
You may have electrical connection issues. I would disconnect all the power and ground connections from the battery forward and clean them if nothing else appears to be a problem.
Once you have checked for codes we will know more. |
Is the car turning over now and is it starting?
(Post 1412330)
It's interesting you're not also getting a 'trac not available' and/or abs light also. If it's transmission related or abs related you may not find a code with a generic reader. You may have to visit a shop with Jag software.
Is your traction control button on or off at the console?
Link http://www.jagrepair.com/images/TSB/...XK%20specs.pdf Look at page 2 of this TSB |
Try a short drive, mine was on after I put front/rear suspensions back together, I'd performed a hard reset but found after a short drive the next time I started it it was off and has been since.
Mine gives me a DSC caution if it sits for over a week. Will either come up with the engine ignition on before start or just after starting. I usually just drive it until it warms up, shut it off and restart and it goes away.
It is always on a battery tender in the garage so I have no idea why it does it. I'm guessing a voltage drop somewhere but am lost why it is only after being idle a week or two |
(Post 1412455)
Center console, same row of buttons as the fog light and hazard light switches. Is there a "DSC OFF" button there? Am pretty sure they all came with ASC or DSC.
Originally Posted by woox4
(Post 1412608)
Hi Guys....I may have the answer to the DSC fault message...Mine did this and I checked online to see what it meant and for any solutions.
Advice was to undo the DSC sensors on top of the wheel hubs (one per wheel) and remove the sensors.....they get gummed up with road dirt and then send a fail signal to the computer which gives you the DSC fault on the display. I cleaned them with nail brush and soapy water and hey presto...the fault disappeared and never returned! That was 8 months ago. It is an easy job and I managed all 4 wheels in about an hour....and yes...they were gummed up with black gunge. Good Luck! |
| All times are GMT -5. The time now is 01:36 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
