Electrical Issue?
Hi all:
I've read several threads and think I know the answer, but I'd like your opinions on this specific set of facts. Car: 1999 XK8, 101K miles, excellent condition overall Background:
Thanks Thom |
Buy a new battery. Every electrical problem thread will tell you that these cars need a battery in great condition and one that has been drained for 6 months will never fit that bill, regardless of how old it is.
^^ +1
Originally Posted by thom4782
(Post 2413670)
I know we have some members who report they can get away with parking up for months on end with no battery maintainer but this is not the majority experience. Graham |
Even if not connected its 100 days to discharge and 100 days to turn to scrap ...so you did that.
Get a new battery and make a plan to routinely drive the vehicle at least 20 miles at highway speed once or twice a week. My wife has not driven her 2006 XK8 in more than a year, yet she wants to keep it primarily as a work of art (astute financial sense has never been her forte). So although I am far too tall to comfortably fit into it and thusly do not enjoy driving it, I make certain to take it out for some spirited exercise a couple of times per week throughout the year. Zero battery issues as a result (it has a three-year old Bosch AGM battery) and the various onboard fluids are kept pumping as well....
Thanks for confirming my guess. Lesson learned with a new battery installed in the car,. There is one remaining issue and I'd appreciate your thoughts. When starting cold after sitting overnight, the car jumps to 3000-4000 rpms for about 30 - 60 seconds. Then it settles down to normal operation. A scan showed no fault codes. I did a hard reset. Any ideas why this may be happening and what I might do to correct it? Thanks
Yeah, I think the replies here might be missing the forest for the trees, or maybe a single tree.
Sure, getting a new battery might be part of the troubleshooting, maybe even the first step in troubleshooting, but it's too dismissive to just leave it at that, especially since even if it's a battery problem, the battery problem might be a symptom of something else going on, like an unexpected drain while the car's turned off. On the other hand, if the battery is less than two years old, maybe the replacement would be free or almost free? One thing to remember is that there are different types of battery tester. A different shop's tester might confirm that the battery is dead. When starting cold after sitting overnight, the car jumps to 3000-4000 rpms for about 30 - 60 seconds. |
Sorry to accuse you of lying, but you started up an XK8 and there were no codes?
That's impossible. |
1 Attachment(s)
(Post 2414072)
Originally Posted by crbass
(Post 2414112)
Did you do a hard reset and 'teach it idle again'? If not, instructions attached...
When you go to start these cars they through a series of (although this might be different model year to model year) adjustments to prepare the TB for running. |
Originally Posted by volkris
(Post 2414080)
Originally Posted by bladerunner919
(Post 2414343)
Car works fine, then parked for 6 months and battery drains - I feel you are overthinking this. Leaving a car unattended for 6 months will always drain the battery - he's not talking about leaving it overnight and it draining!
So it absolutely could be that a battery replacement would clear it all up, but there's enough doubt in that narrative that I wouldn't be so quick to tell someone to pay $150+ to find out. That might not be a fortune, but it's still into the substantial amount of money area. And anyone with these cars needs to save up for bushings and octopus hoses :) If they have the cash sitting around, sure, go for the replacement. It's a quick and easy thing to try. Personally, I'd do more troubleshooting, maybe seeing what happens when boosting from an additional battery or jumpstarter, for example, and doublechecking that battery/megafuse connections are tight. |
