"Entry Delay Warning"
After a short period of driving I am getting an intermittent warning bong, no lights or warning text on the dashboard.
I looked the noise up in the handbook and the sound is "Entry Delay Warning" and the Remedy is "Disarm Vehicle" which makes no sense when its driving. Anyone else had this issue and any ideas how to cure it? Thanks |
Can you say more? How many bongs, just 1? Not a beeper like when you turn car off in drive right? Same noise as when push roof down button, open sequence starts to engage?
Is that the same warning you get when you unlock the door with the key rather than the fob? You then have to put the key in the ignition or the alarm sounds?
Maybe bong to indicate hand brake is still on even though it's not,😕
Originally Posted by Johnken
(Post 2058246)
