Foglight lens issue
The glass lens on one of my 2001 XKR foglights is no longer clear and has turned a miky white. Has this happened to anyone else?
Is a replacement of the whole assembly is the only option? |
unless you can 'clean' the haze from the lens (try buffing it out), then yes, the whole assembly will need to be replaced. Its a DIY job and you can access the mounting points from the fenderwell access cover facing the lights.
