Front ride height fixed
My front height was close to the 416mm limit, with the typical value being 401mm.
My ride height is now 395mm following these changes.
New shock upper mount bush, this would tend to increase ride height.
Correct seating of the springs on the white wedge spacer at the bottom of the spring. The P.O. have new springs fitted to the car by a Jag dealership after an MOT fail in 2009, it has probably been running high since then due to the carelessness of the mechanic.
Removal of one of the two black spacer rings at the bottom of the springs, this will account for the lower than typical height but is what I was looking to achieve.
