Front wheel bearing life
With my XK8 2000 and 45,000 miles on the clock what mileage would I expect to have to replace the front wheel bearings? The car has been a daily driver since I have owned it ( little over two years) and is driven in a very modest way mostly by my wife. And with it being a 2000 year would I expect the bearings to be the upgraded 80mm size?
Thanks for you help guys. EZDriver 2000 XK8 1995 XJ6 |
My first XK8, a '00 with complete maintenance records that did not identify any wheel bearing replacement, made it until 106k miles without any problems. Failure issues more associated with a traffic light.
Worry about something else. |
Had one changed at 122k and now at 169k it sounds like I'm due for the other.
Mine lasted until 100000 miles , then both went within a few weeks ,
I think it was the 20" wheels that laid them to bed :icon_bricks: Nik |
Originally Posted by OregonJag
(Post 487703)
Originally Posted by Skid Mark
(Post 488103)
What do they sound like as they're wearing out?
A test you might try, although I've only used this on front wheel drive. While rolling along a wide road with no traffic, swing the wheel side to side making S-turns. The noise from the bearing will change depending on the direction that you're turning. Sometimes as bad as OFF-ON-OFF-ON as you go from side to side. Don't be so aggressive that you get the tires to make noise, just looking to change the load on the bearings. |
OK, thanks!
With my '97 at 115K, and not knowing if they were ever changed, I have tried some static testing to see if I could hear anything. Wheels off the ground, spin at different speeds, stethescope, 6-12 and 3-9 rocking, etc. I don't hear anything that way, and sometimes I "think" I hear noises on the road, but it could be my tires, the road, or other things. If I ever get to replacing the sway bar bushings I'll give it some more road/load testing.
If you can't hear anything and don't feel any freeplay I would say you're in good shape. The one on mine that's making noise has some free play when wiggling the tire off the ground. That one has made it 169,000+ miles.
