fuel injector relay location 2001 XK8
Old Jun 5, 2015 | 06:29 PM
cobrawet2's Avatar
Default fuel injector relay location 2001 XK8
Hello all
2001 XK8, 4.0
I just did the replacement of the upper cam shaft chain tensioners (Yes, mine had cracks!!!!) and heard it is best to disable the engine and crank it over for a bit to build up oil pressure. Where is the fuel injector fuse location?
I have heard it is on the passenger side (My car is LH drive.....USA) fuse box in engine compartment.
I do not have a fuse box diagram, but have heard it is fuse #5.
There are 2 rows of fuses and would assume it is either the 5th fuse from one of the ends.......not sure row nearest to front of car or back of car, or closest to engine or closest to fender.
Sure would be nice to have a picture.
Thanks all!
Old Jun 5, 2015 | 07:02 PM
test point's Avatar
Pull the relay.
You need to download the full (free) JTIS technical documents.
The fuse chart is in the Sticky above:
https://www.jaguarforums.com/forum/x...8-r-faq-33555/
Here you go on the relay:
File Type: pdf
Old Jun 6, 2015 | 07:58 PM
motorcarman's Avatar
ALL the relays and locations are shown in the Electrical Guide in the 'FRONT MATTERS' section.
ALL the Electrical Guides should be somewhere on the this forum!!!!!!!!!!!!!!!!!!!!!
bob gauff
toronadomike
Jan 22, 2026 10:13 PM
99xk8guy
Sep 29, 2025 10:51 PM
Charlene n John
Sep 28, 2015 06:01 AM
leep123
Sep 12, 2015 06:53 PM
jaguarbill
Sep 5, 2015 11:43 AM
